F430 Rear Tire Suggestions | FerrariChat
Discussion in '360/430' started by BillEllison, Jan 30, 2012.
  1. BillEllison
    BillEllison Karting
    Oct 16, 2011
    89
    Conroe, Tx
    Bill Ellison
    What is the widest size to replace the rears with. Currently have 285/35/19 and want a wider tire without replacing wheels.
  2. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    I am using Bridgestone RE-11. I went up one size on the front with no problems. I kept the rear the factory size.
    F430GT knows a lot about tires. Check some of the old threads.
  3. BillEllison
    BillEllison Karting
    Oct 16, 2011
    89
    Conroe, Tx
    Bill Ellison
    Thanks.
  4. bshah
    bshah Formula Junior
    Jun 28, 2011
    326
    Chicago
    good timing...
    I just received a message from the dealer that one of my rear tires has a nail in it and is losing pressure. Needs to be replaced.
    Pirelli.....$600 installed with taxes.
    I might change both rears...waiting for his reply on the status of the other rear tire.
  5. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Don't mix stock front tires with a different tire model in the rear, that will compromise handling drastically.
    Get a set of 4 RE-11 for the F430, 235/35R19 and 285/35R19 on the stock wheels. Massive increase in dry grip from everything that came available with the F430, and even better dry grip than Pirelli Corsa System, they are affordable tire too.
    I'm still running my almost 2 years old rear RE-11 in the Scuderia, despite of track days, drag races, autocrosses and more than 6,000 miles. They last too long. My Cayman has them as well, and they just don't wear.
    With same usage, I went through 5 sets of Toyo R888 in one year, and the Pireli Corsa System failed my controlled lap times tests at Cal Speedway and autocrosses.
    If you want to fill in the wheel well, either buy new wheels (10" front 12.5" rear) and wider tires, or add a 15mm front and 20mm rear spacer.
  6. Nashtyboy
    Nashtyboy Formula Junior
    Sep 8, 2010
    429
    Raleigh, NC
    Surprised, they're only rated at 180-A-A. I was looking at the RE050 since they are rated 280-AA-A.
  7. aahtt
    aahtt Karting
    Mar 24, 2009
    69
    San Diego
    Anthony H.
    I have 235/35/19 upfront and 295/30/19 rear RE50A on stock wheels and they look great especially with 15mm spacers all around. no issues at all and the car looks a 100% better with them.
  8. BillEllison
    BillEllison Karting
    Oct 16, 2011
    89
    Conroe, Tx
    Bill Ellison
    The look is what I am really going for. May have to seriously consider the spacers, but want to fill the wheel well a little more. Please post a pic of the rear view.
    Thanks.
  9. augustxke
    augustxke Formula Junior
    Feb 7, 2009
    412
    MN
    Bruce
    What is a RE-11 tire? If they last that long for your aggressive track driving, they should last along time my for road use.
  10. tazandjan
    39,163
  11. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Great timing!
    I need to change all 4 tires on mine.
    Do you guys know where to get the spacers F430GT mentioned?
  12. ferrariblue
    ferrariblue Formula Junior
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    I just did all 4 on my F430 coupe with Michellin Super Sport
    295 30 ZR19's and 225 35 ZR 19's in front. These stick like race tires on the street. Amazing!
  13. kreuland
    kreuland Rookie
    Mar 10, 2011
    41
    This must be new! The supersports have'nt been availeable in F430 sizes!!!
  14. arizonaitalian
    arizonaitalian Two Time F1 World Champ
    Oct 29, 2010
    20,505
    Wyoming
    Can you confirm your sizes in MPSS please?
    I don't think they make that front tire size...did you mean 235/35-19?
    Would love to hear that they did start making the stock size...and we have to choose a non-standard rear in MPSS also, either 275/35 or 295/30 rather than the stock 285/35...
    F430GT wrote a comparison of the MPSS vs. RE-11 in another thread for anyone who reads this and wants to get some feedback on MPSS vs. RE-11...IIRC his opinion was that these are the best two combo track day/street tires...with perhaps a slight advantage to the RE-11...
  15. kreuland
    kreuland Rookie
    Mar 10, 2011
    41
    I just searched Michelin's web site and the tires that Ferrariblue quotes do exist but the rolling diameter is off by about 1 cm . Is that ok?
  16. kreuland
    kreuland Rookie
    Mar 10, 2011
    41
    Interrested because I've been running Pzero Corsa and they are great when warm but heard the supersports were even better! Only care about grip, not wear.... any experience out there?
  17. C4YES
    C4YES Formula Junior
    Apr 7, 2008
    992
    Orange County, CA
    Todd
    I have a pair of spacers and bolts that I purchased from Ricambi. The spacers are 11mm thick and the bolts are 11mm longer than stock. PM me if interested in buying.
    Sent from my MB860 using Tapatalk
  18. ferrariblue
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    From my earlier post, my Michellin Supersports are identical in size in the front, but the rear (295-30-19) is 0.8" shorter tire. They do not have a like for like match in size yet. I was concerned at first, but my Ferrari dealer put these on my car; they have done 12 F430's with these tires with no complaints. My other option was the PS2's. I wanted the new compound. These are great tires. The only thing you may notice is your speedometer may read 2% to 3% faster.
  19. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    The rear ride height need to be adjusted 10mm up, or the front 10mm down, the alignment reset. I would use 235 instead of 225 MPSS, due to the excess understeer built into the F430.
    Far much better tire than the obsolete and still good PS2.
