F430 revving while driving | FerrariChat
Discussion in 'Technical Q&A' started by Usflaw92, Jun 7, 2024.
  1. Usflaw92
    Usflaw92 Rookie
    Jun 3, 2014
    19
    Hyde park, Florida
    Avedis Kotchounian
    Unfortunately, I’m back here again… I just replaced the hydraulic lines and blood the car and it’s been working great. This morning while driving in third gear approximately 30 miles an hour, when I went to give it more gas, it started revving. I came to a stop and when I started to accelerate its beeping loudly (same when you take off your seat belt). There are no lights on, nothing coming on the dash.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,410
    San Carlos, CA
    Mitchell Le
    I don't think there is enough information here. The first thing that comes to mind is you need a new clutch. But, there is more to this story I think.
  3. Usflaw92
    Usflaw92 Rookie
    Jun 3, 2014
    19
    Hyde park, Florida
    Avedis Kotchounian
    The clutch reading last week was 82%
  4. yelcab
    Nov 29, 2001
    13,410
    San Carlos, CA
    Mitchell Le
    That means nothing unless you can give some history of .. year, model, mileage, what service was done, by whom, how old is the clutch, what was done right before this and how was it done. My clutch reading was 50% remaining but ... the actual thickness of the clutch plate was below minimum.
    That number means nothing without a lot of context.
  5. Usflaw92
    Usflaw92 Rookie
    Jun 3, 2014
    19
    Hyde park, Florida
    Avedis Kotchounian
    2005 with 24,000 miles
  6. yelcab
    Nov 29, 2001
    13,410
    San Carlos, CA
    Mitchell Le
    OK, how do you drive it? aggressively? Do you have a steep long driveway you back up all the time? Did anyone mess around with the Clutch From New Value?
    24,000 miles on a 430 F1 is probably about right for a clutch.
  7. RayJohns
    RayJohns F1 Veteran
    7,837
    West Coast
    Ray
    My vote would be burned / glazed clutch face.
    Ray
  8. yelcab
    Nov 29, 2001
    13,410
    San Carlos, CA
    Mitchell Le
    And he's going to need a new clutch ...!!!
    tbakowsky likes this.
  9. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,854
    The Cold North
    Tom
    Defiantly sounds like new clutch time. But I will say 24k miles is a bit early. I have a one owner scud with 70k on it,,mostly hard track time its currenlty showing 50%. Gearbox has never been out of the car since put together by the factory.
    Subject car may have had a hard life
  10. Usflaw92
    Usflaw92 Rookie
    Jun 3, 2014
    19
    Hyde park, Florida
    Avedis Kotchounian
    Thank you for all the input so far; I just used a different computer and the readings were as follows
    Clutch wear index: 292
    clutch wear index (percent): 0.891
  11. Usflaw92
    Usflaw92 Rookie
    Jun 3, 2014
    19
    Hyde park, Florida
    Avedis Kotchounian
    Clutch position closed: 20.305
    clutch position closed since new: 19.986
  12. tbakowsky
    Sep 18, 2002
    19,854
    The Cold North
    Tom
    Assuming the clutch reading is 89% worn, its time for a clutch.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,687
    Central NJ
    Dominick
    If the reading are correct
    .which of course is questionable..is only 5.5.precent worn
    Anyone could change the position from new and throw the whole calculation off .
    A visual inspection can identify a worn clutch
