News
F430 Rotors
Discussion in '360/430' started by CarAholic, Nov 6, 2018.
  1. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    258
    Are the 360 rear rotors and pads the same as the F430’s. The more I search the topic the more conflicted information I’m getting.
  2. bellwilliam
    bellwilliam Formula Junior
    267
    Yes. They are the same.
    Brembo 09.7267.50. About $100 per rotor.
    Yes. Ferrari steel rotors are cheaper than my Ford.
  3. mike32
    mike32 Formula 3
    May 13, 2016
    1,638
    Uk
    Look on Superperformance uk web site, all the info and various makes listed
    whatheheck likes this.
  4. CarAholic
    May 10, 2016
    258
    Thanks for all the responses I have placed an order.
  5. CarAholic
    May 10, 2016
    258
    Just wanted to give a big clap to super performance. Ordered my brakes Tuesday night and I received them in the US by Thursday.
  6. mike32
    mike32 Formula 3
    May 13, 2016
    1,638
    Uk
    I will have to ask them for commission
  7. ttforcefed
    ttforcefed F1 Veteran
    8,874
    how much cheaper than the dealer after shipping overseas etc?
  8. goto35march
    goto35march Karting
    Jul 23, 2009
    52
    Awesome awesome awesome!
    Quick question with brembos up front will the brake sensors will work or does that needs to be disconnected with aftermarket
    Crazy how cheap Brembo rotors are!
  9. CarAholic
    May 10, 2016
    258
    No not at all, the sensors are in the brake pads. Just make sure you get front brake pads with the sensors.
  10. mwstewart
    mwstewart Formula 3
    1,337
    England
    Mark
    F430 are not the same as 360: Ferrari went with a different metal composition to improve braking power. The iron discs are marginal on an F430 as it is so personally I wouldn't want to step down.
  11. goto35march
    goto35march Karting
    Jul 23, 2009
    52
    im buying a car that the brake sensors are zip tied and not installed. i guess that means the front brake pads are not ones that sensors can be installed in. i'll replace the brake pads with sensors.
  12. CarAholic
    May 10, 2016
    258
    Never heard this before but even so unless your tracking the car you will never notice the difference.
  13. mwstewart
    mwstewart Formula 3
    1,337
    England
    Mark
    I have to disagree with that. I've owned two 430's - iron original rotors and CCB. If using the performance potential of the car I found the iron brakes were easily overwhelmed. They aren't up to the weight and power of the F430. I haven't been on track with either.
  14. steelej
    steelej Formula Junior
    Jan 15, 2007
    428
    I've been running 360 disks on my 430 for about half the time I've owned the car which will be 10 years this year and coming up for 40k miles, I've noticed absolutely zero difference on road or track.
    John.
  15. CarAholic
    May 10, 2016
    258
    CCB’s are completely different let alone much large diameter then the steel brakes. It can’t be compared to a slightly different coating on the steels. No average person would ever notice the difference between the two steels.
  16. mwstewart
    mwstewart Formula 3
    1,337
    England
    Mark
    For sure. What I'm saying is the CCBs highlight the deficiency even more. Fitting the lesser 360 type rotors seem a backward step to me. My experience is a few hard stops from triple figures and the iron brakes are saturated.
    If they work for you then no issue.
  17. working on my cars for all these years, i have to say the brake system is the most complicated system to understand for me ( not per se).
    it is hard to understand why my 360 6speed manual's brake feel so much better than my CS's brake although my CS discs are weighed as still ok to use and the pads are brand new (break-in done). And my 360 6speed's brakes are almost 20k miles!!
  18. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    5,170
    Campbell, CA
    John Zornes
    As I recall, the CS has carbon brakes so there should be no comparison. If your steel brakes are acting better than the carbon brakes there is something very wrong. I would start by flushing the system and if that doesn't work look at removing the calipers and clean them up. You likely have some obstruction in the lines.
  19. let me rephrase, my CS brakes are ok, i tracked it, drive it spiritedly, no problem, compared to my friend's scud and other ferraris, it is no proabably except some small faint noise meeting a red light.
    it is just my 6-speed MOdena's brake are a lot BETTER than my CS. I mean better feel, better response from my foot, not necessarily better stopping distance. This is not my impression only, all people who drove my 6-speed are amazed by this particular car's brake. Just so not understanding it.
