F430 Scud question, thx in advance! | FerrariChat
Discussion in '360/430' started by Buckus, Apr 2, 2012.
  1. Buckus
    Buckus Karting
    May 21, 2007
    65
    Jersey Shore
    Morning, I just purchased a 2008 Scuderia.. 2 days into it i get a check engine light. Stock exhaust, no mods. I was told to disconnect the power (somewhere in the front bonnet is a power source) but where??? Anyone know where this might be? Thx
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    #2 greyboxer, Apr 2, 2012
    The clearest safest answer is in the owners handbook - section 5 maintenance
  3. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    Passenger side of front bonnet, has a cap over it. You can use a torx bit to turn it on and off. Make sure you have the radio code!
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    You were told to disconnect the battery; By whom? and for what reason?
    CE lights should be investigated with an OBDII reader or SD2/3 not by blindly resetting the vehicle electrical system. It is true that this might fix specific issues but I recommend starting with the scientific method. We are here to help, so post the OBDII code(s) and lets work from there.
  5. Prancing 12
    Prancing 12 F1 Rookie
    2,757
    The long way home
    Good advice.
    Better advice.
  6. arenared
    arenared Karting
    Dec 22, 2005
    211
    Silicon Valley
    +100. You're throwing away valuable diagnostic information, especially, if it's an intermittent problem. On the 2008, I believe there is a switch near the rear of the front "bonnet". This is not present on the 2009.
  7. watt
    watt Formula 3
    Jun 17, 2004
    2,274
    Northern Rocky Mountains
    Giuseppe T Hemingway
    I've done 1800 miles in the last two months and now the check engine shaped light is staying on but car feels fine..... 2009 scud with 4k miles.
    is it go to dealer time? thanks
  8. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Safe to say, yes.
    Fresh off my iPhone via Tapatalk
  9. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    Get the OBD2 codes. You can borrow a reader from "most" autoparts stores for free. If you start your scud once before the "OK" light, you could have the CE forever until reset by OBD2 or SDx. It will ay misfire on cyl 1,2,3,4,5,6,7,8, just because you started a fraction of a second before you should have. I used to get this CE often as a impatient newbe. Now I just wait and never see it. Just an example, you issue could and is likely different. But do a bit of homework, it might feel good to learn a bit about your fabulous machine. Think of it as asking your significant other whats wrong when she has her CE light on.
  10. watt
    watt Formula 3
    Jun 17, 2004
    2,274
    thanks guys...
    i doubt its starting too early... the bummer in LA now is using autogallery service unless i want to flatbed to FOC...
  11. crazy canuck
    crazy canuck Formula Junior
    Jun 20, 2005
    426
    West Coast
    Where is the obd port on an f430?
    A picture would be nice to see if anyone has one available
  12. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    No pic needed, it cant be missed. Its up under the dash, just beside the steering column on the right. Its not covered or anything, its black.
  13. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    #13 Trent, Apr 15, 2012
