430 - F430 shock absorber replacement | FerrariChat
430 F430 shock absorber replacement
Discussion in '360/430' started by Salsero, Mar 6, 2021.
  1. Salsero
    Salsero Karting
    Oct 6, 2006
    198
    MY
    Rezal
    The front right shock absorber has thrown a fault code.
    Is it possible to just replace 1 corner? Been told that these shocks are pretty hardy but also been advised that I should replacement both Left and Right front corner.
    Problem is that brand new, OEM shocks are super pricey (x 2 for both corners) and if I buy used, even if I get L & R pair, I cannot be assured that they're from the same car. So obviously the cheapest route is to buy just the Right Hand Front corner used.
    I'm assuming that given the sophistication of these shocks and the self adjusting nature, 1 corner replacement is acceptable.
    Thoughts?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    #2 mike32, Mar 6, 2021
    I have an idea you can get them serviced, someone might clime in with info. They generally replace pairs but depends on use i suppose
    Where are you located ?
    Found Caprainzcnc.com. Also DK Engineering in uk do a rebuild service
  3. Salsero
    Salsero Karting
    Oct 6, 2006
    198
    MY
    Rezal
    Unfortunately, I'm in Malaysia.
    Car has 26k miles btw
  4. colorfull
    colorfull Formula 3
    1,940
    Franklin Park, New Jersey
    John Napoli
    I have made this quest and found the best solution
    Reach out to Leo at madenoracing.com
    He will have answers to all your questions, knows everything about the topic and costs are very fair.
    Need4Spd likes this.
  5. Danedingerson
    Danedingerson Karting
    235
    Maui
    Dane
    Mine threw a code ,then it didn't come back after I erased it.
    . Dealer said not to worry.
  6. Salsero
    Salsero Karting
    Oct 6, 2006
    198
    MY
    Rezal
    This is not a code error. Definitely a fault with the shock absorber. Not sure if shipping to Europe for repairs and then back to Malaysia makes financial sense.
    My original question remains - given the adjustable nature of the F430 shock absorber, is it possible to replace just 1 corner or do I need to replace both L & R sides?
  7. 24000rpm
    24000rpm F1 Rookie
    yea of course its possible.
    most people won't notice any driveability issue anyways, even if you replace it with a aftermarket one with different damping force.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Did u look at the website i put up- does it have this sort of adjuster.
  9. Salsero
    Salsero Karting
    Oct 6, 2006
    198
    MY
    Rezal
    Unfortunately, the link Caprainzcnc.com. didn't work for me
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    My spelling, i missed out the t
    Try. captainzcnc.com. Look at the diagnosis tag. Not sure if 430 has this as cannot see mine without taking wheel off
