F430 Smog Check -- CST, ABS and BRAKE lights | FerrariChat
Discussion in '360/430' started by cryhog, Jul 19, 2010.
  1. cryhog
    cryhog Rookie
    Mar 3, 2009
    26
    Los Angeles
    I got my new F430 smog checked last week and driving it home the CST and ABS lights were illuminated, which I was sort of expecting due to the dyno. After a couple miles they went away and the "Suspension Error" light was still on the main display.
    However, I drove it again today (first time since last week) and the CST and ABS lights are back on, along with the BRAKE light. I'm *assuming* that this is just due to the smog check and I drove it around a bit and I obviously still have brakes, but needless to say I'm pretty worried given the dire warnings in the manual about the CST ABS BRAKE combination.
    Help?
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I think help is at your local dealer who can read the codes and decide if they just need clearing or something else is wrong. Why would you want to mess with anyone else?
    Good luck,
    Dave
  3. cryhog
    cryhog Rookie
    Mar 3, 2009
    26
    Los Angeles
    Yeah, that's what I'm planning on doing, except the local Ferrari dealer isn't so local and given the dire warnings in the manual I'm a little worried about driving it at all, you know what I mean?
  4. TheMayor
    106,147
    Vegas baby
    Any warning lights that have to do with the brakes or traction control are going to be printed in bold red type in the manual -- by their lawyers. They don't want anyone driving it with any possible problem in those areas for their own sake.
    I do suggest you bring it to the dealer as soon as possible though. If you call them, I'm sure they will just say bring it in.
  5. hardtop
    Jan 31, 2002
    11,294
    Colorado
    Dave
    Assuming it's under warranty, you can probably get it transported to the dealer on their nickel. Ask about it.
    Dave
  6. cryhog
    cryhog Rookie
    Mar 3, 2009
    26
    Los Angeles
    Just to update...
    Took it to my local shop (Independent Ferrari expert) and he hasn't been able to clear it from the computer. Even disconnected/reconnected the battery and no luck yet. Still trying to figure out what the problem is, as the car is "stuck" in "Rough Road" mode.
    Doesn't think it's anything mechanical and it seems almost 100% that the smog check caused it, so... crossing my fingers it's nothing too serious. My guy isn't super concerned, so that's a plus...
  7. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    I had all my lights blinking simultaneously and after a long troubleshooting the cause was the voltage regulator. It happened every time I pushed the gas. Just a hint but for sure your dealer will found the cause.
    Good luck.
  8. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    subscribed...
  9. cryhog
    cryhog Rookie
    Mar 3, 2009
    26
    Los Angeles
    Well, this took a strange turn...
    Finally got a call back from my shop - the lights were totally unrelated to the smog check, it was just a VERY badly timed coincidence. The wiring leading to the front right wheel sensor had been chewed away by rodents or something. Teaches me to park it in the mountains, apparently...
    So, lesson today that I've learned: Even though things may look, from every reasonable standpoint to be closely related, they may not be. And I need to get some outdoor cats.
    AHudson likes this.
  10. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    So when hooked up to an SD3 computer it told the operator it was a ABS Wheel Sensor NO SIGNAL fault, which I assume the wire was then checked and volia! Damaged wire issue resolved. How did they solve the problem? Was it a replacement piece of loom or something else?
    How much did they charge your for;
    1) hooking up sd3 and pulling the fault code
    2) replacing the piece of broken wiring?
    3) total labor
    Glad your car is now fixed again!
  11. cryhog
    cryhog Rookie
    Mar 3, 2009
    26
    Los Angeles
    Yep, that's exactly what happened. $400 for all of it - locating, repairing the wires, etc. Seemed pretty reasonable to me!
    Glad to have my baby back :)
