F430 Spider F1 Oil on Muffler | FerrariChat
Discussion in 'Technical Q&A' started by Targa80, Sep 14, 2024.
  1. Targa80
    Targa80 Rookie
    Oct 29, 2023
    36
    Baz
    Hi Folks, found what looks to be dried oil on the muffler, which seems to have happened when I slowly reversed the car into my drive which is on a small incline (few degrees).
    It dried like plastic onto the muffler as shown in the photos.
    Is this engine oil or something else?
    I checked over the engine, gearbox and F1 system and could not find any leaks (car is running fine).
    The only thing I noticed was the oil cap had worked itself slightly loose (about a 1/3 turn), which it tends to do for some reason. So possibly some oil spurted out of the oil cap onto the engine lid and worked its way back to the muffler?
    Does this sound like the root cause or something else at play here? And if so, is this something to worry about or just make sure the cap is tight before each drive?
    Ps. It’s a mint 2007 Spider F1 with 17k miles.
    thanks!
  2. wmuno
    wmuno Formula Junior Silver Subscribed
    Dec 24, 2007
    522
    Wilmette, Illinois
    Bill Muno
    If this was my car, I would clean the muffler and monitor that spot after each drive for the next several weeks. It will be easier to find the source of the leak when things are still wet. Once dry the path of the leak might become hidden.
    BAK5150 likes this.
  3. Targa80
    Targa80 Rookie
    Oct 29, 2023
    36
    Baz
    Thanks - yes have cleaned it and been for one drive, but no signs of any leak
  4. wmuno
    Dec 24, 2007
    522
    Wilmette, Illinois
    Bill Muno
    That’s positive. I would keep checking it for several more drives.
    BAK5150 likes this.
  5. windsock
    windsock Formula 3 Rossa Subscribed
    Nov 29, 2006
    1,153
    looks like melted plastic or a melted fender cover. Ask me how I know about the melted fender cover part. That can be removed with a plastic scraper and then polished.
  6. Targa80
    Targa80 Rookie
    Oct 29, 2023
    36
    Baz
    Yes, felt like melted plastic (I’m not sure what dried/melted oil would look like). I scraped it and then polished (looks like new).
    What is the fender cover part you mention please ? I can the inspect and see what I find :)
  7. Targa80
    Targa80 Rookie
    Oct 29, 2023
    36
    Baz
  8. windsock
    Nov 29, 2006
    1,153
    Fender covers are what we use to put on the cars to protect them while servicing them. Most are a synthetic material. Image Unavailable, Please Login
  9. Targa80
    Targa80 Rookie
    Oct 29, 2023
    36
    Baz
    Thanks - it was serviced by Ferrari in July, and I’ve done about 300miles since then, so think I can rule that out for now. Thank you
