430 - F430 Spider limited to 2nd Gear | FerrariChat
430 F430 Spider limited to 2nd Gear
Discussion in '360/430' started by RichardCH, Aug 21, 2019.
  1. RichardCH
    RichardCH F1 Rookie
    4,661
    So after coming back from Italy on a 4 hour drive, everything was fine with my F430 spider. The next day the gearbox and engine light came on and the battery sounded weak. I switched the battery and then went for a drive and the cars run smoothly but still have the same issues. I guess this is the F1 or Gearbox Sensor ?
  2. ttforcefed
    ttforcefed F1 World Champ
    19,233
    sure sounds like it.
  3. BlacktopRacing
    BlacktopRacing Formula Junior
    996
    Pittsburgh
    Dale
    By any chance, did you hook up an OBDII reader and get a p2794? If so, did you get an advanced reader and narrow it down to a p1741? I ask because that's where I'm at with the same issue. As a note, if you really need to drive the car, such as to the shop, you can get above second gear by reaching a high speed in second, pulling both paddles to reach neutral, then pull the "Up" paddle and it will select 3, 4, 5, or 6 gear.
  4. RichardCH
    RichardCH F1 Rookie
    4,661
    it going to the Ferrari stealership tom am but they at least let me supply the parts
  5. BlacktopRacing
    996
    Pittsburgh
    Dale
    Which dealership is near you? Aslo, will you share with us what they tell you?
  6. RichardCH
    RichardCH F1 Rookie
    4,661
    do you think I have been a ferrari owner for the last 15 years on this forum for any other reason ??
  7. RichardCH
    RichardCH F1 Rookie
    4,661
    thanks for the tip about getting above 2nd gear, will have to wait a few days for them to diagnose though, I will paste part no when I know
  8. RichardCH
    RichardCH F1 Rookie
    4,661
    Seems my F430 Spider problem is my F1 Potentiometer part number 248095, any one else had this ?
