F430 Spider - Removing Engine Bay Covers | FerrariChat
Discussion in '360/430' started by Jonathan White, Oct 29, 2018.
  1. Jonathan White
    Aug 9, 2018
    11
    Cotswolds, UK
    Jonathan White
    #1 Jonathan White, Oct 29, 2018
    I may be missing something obvious but once the rear two smaller covers are removed, is there a trick in removing the two larger covers? Once all the bolts are removed I'm struggling to manouver the covers fully off as they seem stuck between the engine support frame rail and convertible top cover panel, I can only raise the convertible top cover panel to free up space when the engine cover is closed so I'm stumped!
  2. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,105
    South Florida
    Greg S
    Should pull straight out
  3. Jonathan White
    Aug 9, 2018
    11
    Cotswolds, UK
    Jonathan White
    That's what I expected but the hood panel (in its closed position) restricts movement of the covers such they don't seem to be able to be manouvered out and it diesn't seem possible to partly open the hood / raise the panel with the engine cover open?
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,782
    Put some masking tape along the edges of the body to protect them. You must pull towards the rear of the car.
  5. Jonathan White
    Aug 9, 2018
    11
    Cotswolds, UK
    Jonathan White
    Thanks - as long as I'm not missing a procedure, I'll give it another go over the weekend.
