F430 spider soft top problem | FerrariChat
Discussion in '360/430' started by psb1013, May 23, 2019.
  1. psb1013
    psb1013 Karting
    Feb 4, 2017
    129
    Lately, the soft top on my '06 430 spider has been opening and closing extremely slowly. Sometimes, the process would stop halfway and I would have to keep playing with the lever to eventually finish the process. Is it because the hydraulic fluid is too low? bad battery? (I had the battery changed last year and the car is always on a trickle charger when not used). Or is the soft top motor finally on its last legs?
  2. hessank
    hessank Formula 3
    1,888
    Canada, Florida
    Fred
    Could be all three individually or a combo.
    So why not eliminate the fluid issue by checking the level or even changing the fluid assuming the fluid is 13 years old?
    Lots of DIY threads here with beautiful pictures
    Secondly, do not operate the top with battery power only. Ensure the car is running. If the battery is good enough to start the car on its own then with the car running you could also eliminate a second concern.
    whatheheck likes this.
  3. 00 550
    00 550 Formula Junior
    Oct 20, 2009
    412
    FL
    That guy
    Mine is doing the same and leaking a small amount of hydraulic fluid onto the plastic window that I tracked down to the main cylinder
    (see part number below) in the headliner...I haven't replaced it yet but I am planning on using this company is it seems very economical. If anyone has experience with this company, any information would be greatly appreciated. https://cabriolethydraulics.com/
    Part # 66454700 FRAME TOP SEAL MAIN CYLINDER
  4. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Have you checked the elastic bands in the top?
  5. 00 550
    Oct 20, 2009
    412
    FL
    That guy
    Update. Got the front cylinder back from cabriolet hydraulics. Turn around was one day, granted we are both in Florida, but its still kick ass. Me and my son installed. Took 30 minutes. Refilled hydraulic fluid, and 4-5 cycles of up and down over the course of 5 hours to prime/flush (was worried about pump overheating) so we were patient. Top opens and closes like a beast. Total price around $250 plus simple labor. No affiliation, but very happy with product, price and result!
    Apollo 11 and hessank like this.
  6. hessank
    hessank Formula 3
    1,888
    Canada, Florida
    Fred
    Great feedback.
  7. mike guenther
    mike guenther Rookie
    Jul 6, 2019
    1
    mike guenther
    All great feedback, but looking through the threads, not sure if anyone else has this issue with their top, but mine opens perfectly fine, but will not close if the engine is hot , ONLY when it sits and cools way down, will it close. Not sure if this is low hydraulics or something else ?? As I just purchased vehicle a week ago.
