F430 TCU question | FerrariChat
F430 TCU question
Discussion in '360/430' started by mjz, Dec 30, 2013.
  1. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    When a battery is swapped out - does the TCU have to be re-programmed back to factory settings? I noticed my car is shifting differently than it did prior to the battery change and seems the computer settings are not the same anymore. It's not bad, just different. But I prefer the performance I had before the electrical system was turned off.
    Comments?
  2. tazandjan
    39,334
    Michael- Changing the battery should not have any affect on the programming in your F430 F1 ECU/TCU, which uses a EEPROM to hold the algorithms and maps. Low batteries or bad connections or grounds can affect shifting, but not because the TCU programming was affected.
