F430 ticking sound from Engine bay | FerrariChat
Discussion in 'Technical Q&A' started by Rishi Juta, Jul 1, 2022.
  1. Rishi Juta
    Rishi Juta Rookie
    Apr 21, 2022
    1
    Johannesburg
    Rishi Juta
    Hi all,
    I was wandering if anyone has an idea as to why I am hearing a ticking sound from the engine bay?
    The noise sounds like it is closer towards the front of the engine as opposed to the rear.
    The engine light came on briefly but then went off as well.
    Thanks for any feedback.
  2. wmuno
    wmuno Formula Junior
    520
    Wilmette, Illinois
    Bill Muno
    Your question is too general for a specific answer. Take a plastic hose; hold one end to your ear; and use the other end to find the specific location of the ticking sound. Post the results back here and maybe you will be able to get some help.
  3. swc5150
    swc5150 Formula Junior
    696
    Wisconsin
    Scott Calderwood
    Could be a cracked exhaust manifold perhaps, but yes too general a question without a reference. I will say do not drive it if there’s a chance it is a manifold. You could do some serious engine damage.
  4. f355spider
    f355spider F1 World Champ
    18,031
    Could also be a warped exhaust manifold flange, where it meets the cylinder head. This is common on the Scuderia and 16M, and has been posted as happening on F430s as well. When it warps, it will stretch and/or break the studs causing a leak. That is the ticking noise you hear on cold start. If it is not too bad, it will go away when the engine is warmed up. It if is bad, you may hear it all the time. I'm having the job performed on one side of my Scuderia right now by Windsock (other side was done 7 years ago). He removed and machined the flange flat, and then is replacing all the studs and gaskets.
    In any case, you will probably need a careful inspection by a specialist.
    There is a thread or two on Fchat from people that diagnosed and fixed it themselves. But way beyond my capabilities...
  5. f355spider
    18,031
    tbakowsky likes this.
  6. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,827
    houston/geneva
    Ross
    sounds like new header time for your 430
  7. Circle K
    Circle K Karting
    Dec 21, 2017
    154
    KC
    It’s a diverter valve, can be accessed through the fronk, remove the three mounting screws. I disconnected mine. Only drawback, I have no heat, which I hardly use
