F430 Timing chain noise concern? | FerrariChat
Discussion in 'Technical Q&A' started by GG-33, May 26, 2015.
  1. GG-33
    GG-33 Karting
    Apr 28, 2014
    76
    Farnham, UK
    Greg
    I seem to be getting a rattle that sounds like timing gear, between 2500 and 3250 RPM. I can only hear it when the roof is down and the noise disappears above 3500 RPM. I'm hoping I'm wrong about the source of the rattle. Has anyone else experienced similar?
    Car only has 11000 miles..
    GG-33
  2. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    Maybe a loose or broken exhaust bracket. Mine makes a similar noise at same rpm. I've had both brackets replaced twice. I have the feeling they're broken again.
  3. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    Check the hardware holding the grille between the tail lights and also the grille in the diffuser. Both of mine were loose and made a rattle noise at about the same RPM. No noise since re-tightening everything.
  4. GG-33
    GG-33 Karting
    Apr 28, 2014
    76
    Farnham, UK
    Greg
    Thanks guys, I was tapping some part last night and discovered that the grille between the tail lights seems to rattle a bit. I'll re-tighten everything tonight...hopefully that will do it.
    GG
  5. blackbolt22
    5,808
    Boca Raton, FL
    Mr. Anderson
    Thanks. I'm going to investigate as well.
