F430 top problems | FerrariChat
F430 top problems
Discussion in '360/430' started by Drflint, Oct 11, 2019.
  1. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    Have replaced the 3 hydraulic cylinders in my 2005 F430 spider top front left and right due to leaks .The other 2 cylinders in the body of the car do not appear to leak but the tonneau cover will not completely close on my folded top.According to mechanic next step is to replace the non-leaking cylinders. Did buy new ones at Ricambi but new mechanic in Florida says rebuilt are better when he does them.Any other thoughts on the top malfunction.
    gsworld2014 likes this.
  2. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Has the centre bar in the middle of the roof, retracted? The elastics that loop around it, and pull it back, break and the bar stays up and does not allow the material to fold correctly and doesn’t trigger the close switch properly. Just have a look, as mine had the same problem.
  3. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    hessank likes this.
  4. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
  5. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    this was replaced 3 yrs ago and I did not check it this time but will do so --thanks for your reply
  6. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    turned out to be the elastic
  7. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    you were correct
  8. colorfull
    colorfull Formula 3
    2,337
    Franklin Park, New Jersey
    John Napoli
    Thank you all for the advice, I appear to have the same problem with the center bar (or would at least like to rule it out if not)
    Does anyone have a picture that is not so zoomed in? I can't seem to find this bar, not sure where I'm supposed to be looking
    THANK YOU!!!
