F430 TRACK TYRE ADVICE REQUIRED | FerrariChat
Discussion in '360/430' started by psw, Jul 17, 2007.
  1. psw
    psw Formula 3
    Nov 17, 2005
    1,885
    AUSTRALIA
    Peter
    Hoping someone can speak from experience as to this question, I was aware Ferrari advise against the use of slick tyres on a 430 because of E-diff & ABS issues and warranty, has anyone used sticky tires on their 430 for track club use.
    I have just bought a set of Hoosiers and been advised by my dealer about problems with Slicks, the R6 Hoosiers are not slicks but they are a DOT tyre, albeit very sticky.
    I would appreciate any experience other 430 owners have had on this question.
  2. pbfoot
    pbfoot Karting
    Jun 2, 2007
    124
    I don't have a ferrari but if you need a track tire that's not a slick but has plenty of traction check out yokohama advan A028 or A032R. Nitto also makes some good sticky tires that are closer to street spec (though both the tires I've mentioned are DOT legal, I believe)
  3. AeroGT3RedWing
    AeroGT3RedWing Formula Junior
    Nov 14, 2004
    631
    Central Coast, Calif
    Tim P.
    What's your experience on track? If you haven't been doing it for a long time, you're unlikely to even be capable of bringing slicks up to temp!
    In any case, slicks are a bad on Ferraris and even the track ready Porsche's. The suspension members don't support the loads, and the electrical systems don't either.
    Try Michelin pilot sport cups or Toyo RA-1's. Both are great r-comps that will be pretty quick.
  4. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    I am going to use Michelin CUP tires.
  5. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    Ferrari use the Bridgestone RE050A tires for the driving school at Fiorano. I think they would know best. The F430 Challenge cars are on slicks at the school but the Challenge cars do not use the E-dif.
  6. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,065
    socal
    How can you not track your ferrari is beyond me. This is what these cars are made for. Not able to use R compound tires would be the most important reason to not buy a 430. I would recheck this info. 430C's runslicks but i do not know how the electornics is set up. I thouht the only issue with tires was that the computer looked for the same front to rear factory spec for overall diameter and people where having problems with aftermarket wheels and tires. On the surface I can't see why you can't use any tire so long as you stay to stock sizes.
  7. Private_Joker
    Private_Joker Formula Junior
    May 2, 2007
    271
    718 and 978
    Tom
  8. Private_Joker
    May 2, 2007
    271
    718 and 978
    Tom
    2nd, ABS only needs the overall diameter to be the same.
    http://www.miata.net/garage/tirecalc.html
    There's a very simple size calculator, you can mess around with tire and wheel sizes to make a perfect match to your stock combination (if changing wheel size). If just changing tires, get the same width and profile and that's all.
  9. psw
    psw Formula 3
    Nov 17, 2005
    1,885
    AUSTRALIA
    Peter
    Thanks for all your comments, I have used numerous R compound tyres on previous cars and always found Hoosier a better choice IMO, Hoosier R6's are not slicks as mentioned in my first post they are are DOT approved tyre, my concern after purchasing the tyres was I was told slicks were an issue with the E-diff, I was a little concerned about the Hoosiers as Ferrari here in Aussie recommend Corsa's.
    I chose the Hoosiers over Corsa's & Pilot Sport Cups which I have used previously as the Hoosiers come up to temp much faster than the others and when you are competing in timed lap dashes where a warm up lap, followed by 2 flying laps is all you get, the others don't really reach their best performance until the 2nd lap whereas the Hoosiers are up within the first lap.
    All this said I ran the car today at Eastern Creek Raceway with no problems what so ever, the car was awesome & the tyres sensational as I had expected. They really allow you to feel the limits of adhesion so much earlier and hence push towards those limits with infinitely more confidence.
  10. Ducati
    Jan 23, 2004
    364
    So. Cal
    Joe
    Hi Peter, What size Hoosier R6's did you use on your F430?
    thanks
  11. psw
    psw Formula 3
    Nov 17, 2005
    1,885
    AUSTRALIA
    Peter
    I had new wheels made 8.5" front with 235/35 x 19 and 11" rears with 295/30 x 19. I didn't have time before this meet, as I only just got the car, to put the new lower progressive rate springs in or dial in some negative camber.
    Will do that for next time, as I got faster & pushed a little harder there was still some understeer and I really need to do something with the pads, couldn't believe how quickly the standard steel rotors & pads started to fade.
    cheers
    Peter
  12. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    I ordered Neez mag wheels 11 x 19 and 8.5 x19 with Michelin Cup tires.
  13. psw
    psw Formula 3
    Nov 17, 2005
    1,885
    AUSTRALIA
    Peter
    Nice one, sounds like we both got the sizes right, just a personal preference on the tyres. Hope they work well for you, if you want something stickier again than the Cups try the Hoosiers they are sensational on the 430.
