f430 transmission issues | Page 2 | FerrariChat
Discussion in '360/430' started by 1958bret, Jun 21, 2014.
  1. Jackson32
    Jackson32 Rookie
    May 29, 2017
    48
    North Carolina, U.S
    Jackie
    Bret,
    I have the exact same issue as you right now on my 430, everything works fine until it gets warm, then when slowing down it drops into neutral until car is cooled off, but then skips gears 3 to 5 for example.
    I was told $5500 to send the accumulator and actuator off to GTE for rebuild from my techs as it was "loosing pressure" was their diagnosis, also was told that I have F1 fluid in the engine or gear box, but called two different independent Ferrari shops and was told the same thing by both, that they think air is in the system since it was just serviced in March and did not give any issues before hand and to remove the accumulator to check the bleed screws as they are known for backing out. Waiting on computer and oil to be delivered on Thursday for the bleed procedure.
  2. f1canada
    f1canada Rookie
    Sep 11, 2016
    36
    Montreal, Canada
    Hello Bret1958,
    I was wondering, did you find the issue finnaly with your car.
    I have the exact same issue. Iam being told to replace the complete system also and, no ne can find the problem.
    They also had me change the accumulator ball and, I am still getting stuck after 30 minutes or so, like yours.
    Did they ever find the problem?
    Here they are saying full system or, syncro gears in the transmission.
    Please let me know. It has been 3 months now that I cannot drive the car.
    Thanks!
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    $2500 for new accumulator- about $500 for the part and 2 hours max time. Robbery
    brogenville likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Try bleeding using the bleed screw of the valve block behind the header tank. 8 mm 1/4 inch drive socket. You can do no harm as oil will dump back to header tank removing any air
  5. flyboy
    flyboy Rookie
    Jul 18, 2008
    41
    Ludington Michigan
    Les Kaines
    MY F430 is doing the same thing shifting out of gear when slowing down. turning car off for 15 seconds then start works ok. So far only does it when AC is on which shouldn't have anything to do with it but ambient temp is above 75F.
  6. ttforcefed
    ttforcefed F1 World Champ
    19,241
    i converted to manual. problem solved!
    cavlino likes this.
  7. blackbolt22
    blackbolt22 F1 Veteran
    5,803
    Boca Raton, FL
    Mr. Anderson
    Not exactly. My MT 430 has had unresolved gearbox issues for 6-7 years, maybe more ... Still not corrected after $20K and over countless visits, 2 different mechanics and minimum 6 months of shop time . Searching for mechanic #3 now..
  8. ttforcefed
    19,241
    Which shops?
  9. flyboy
    flyboy Rookie
    Jul 18, 2008
    41
    Ludington Michigan
    Les Kaines
    I have the same issue with my 430 shifts into N when slowing to stop and will only shift after turning car off and waiting 20 seconds then restart and it will shift into 1st. I have a Maserati with the same system for 8 years that has never had the problem Would love to hear if someone finds the actual solution.
  10. tazandjan
    39,117
    Eight years ago. Sure hope so or he had a very expensive lawn decoration.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Have you tried cracking open the bleed screw on the F1 solenoid block, it bleeds fluid from the pressure side back to the tank return line. If any air it will return it to the tank. Can be reached from the hatch for the f1 tank or easier to take the rear wheel liner out. It is a long hex nut 8 mm socket size with a screwdriver slot on the top.
    Crack it until pump cuts in, then shut and repeat.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    Flyboy
    Every issues has to handled separately since even though they sound the same most of the time they are not
    I am more than willing to help you in a phone call if you like ..let me know
    Your issues is probably (since i haven't spoken to you )
    Accumulator
    A true bleed
    Leaking solenoid
    Loose screws
    Bad sensors
    No specific order..
    The phone call and a diag tool can eliminate some of the above
    AHudson and ditpixs like this.
  13. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,907
    The Cold North
    Tom
    Anybody who says they need to replace the entire system to fix the problem..has zero business under the hood of that car. Some of the horror stories I read on here are disgusting.
    What are the faults being generated when it is scanned? Is "incorrect gear selection" one of them? Does the gear indicator flash when the problem occurs, or does the gearbox error light show ( the gearbox error light usually indicates a hydraulic issue..flashing gear indicator usually points to a selection problem)
    cavlino, Flyingbrick242 and ditpixs like this.
  14. AndrewPiper288
    Jul 4, 2022
    8
    Andrew Piper
    2nd that - when i owned mine same issue same resolution - only lasted another year before it needed another one - ended up selling it.
  15. blackbolt22
    5,803
    Boca Raton, FL
    Mr. Anderson
    I think my transmission is a lemon. 2nd mechanic completely disassembled,cleaned , inspected ..everything. It helped a bit... but then went back to hell in no time. I guess one day I'll get around to fixing it or burning it...
  16. domo72
    domo72 Rookie
    Jan 9, 2019
    6
    ditetro davis
    Hello members ,
    Owner of a 2008 Ferrari F430. Car wont shift past 2nd gear both auto and paddle. Also F1 gearbox light came on suddenly. Had actuator rebuilt in 2017 and accumulator replaced in 2020. Any suggestions what the issue might be before i bring to a mechanic or Ferrari dealer.. thanks
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    I have helped a number of people on here this year ..each occurrence and problem is different. I also found that the best use of everyones time is a phone call or two to give you some guidance / possible issues. I do this out of a passion for the brand and have become very familiar with the f1 system etc
    If you like I will be happy to talk ..send me a PM and i will respond accordingly
    cavlino, AHudson, domo72 and 2 others like this.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    One thing I suggest to everyone with a f430 ..get a good diag tool (minimum a old version of a ap200(white ) or a thinkdiag..this is money well spent
  19. tbakowsky
    Sep 18, 2002
    19,907
    The Cold North
    Tom
    4 normal failure points on the f1 system.
    1. Worn clutch
    2. Shift potentiometers
    3. Accumulator
    4. Pump motor.
    Never have I seen a complete system failure..it's basicly impossible. Internal leakage is rare..other then the ediff solenoid. The system is very basic.
    cavlino, domo72 and flash32 like this.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    I would add a clutch EV solenoid and loose screws
    tbakowsky likes this.
  21. f1canada
    f1canada Rookie
    Sep 11, 2016
    36
    Montreal, Canada
    Hi!
    No code generated, no flashing...Just goes on neutral and cant shift any gears anymore. after 15 minutes, I can gear back and drive again...until the next day if I take it again.
    This is what is weird...
  22. 2bf360
    2bf360 Karting
    Dec 18, 2014
    60
    WA
    Heng
    I’ve had the same problem like everyone else mentioned. I replaced f1 pump didn’t solve it. Then replaced accumulator since I read somewhere it said after 10 years it’s going bad or loosening the air precharged something like that. Removed the f1 actuation and checked the bleed screws were tight not loose. Each part removed and replaced had did the airbleed and problems still persisted. Drove fine first 20 minutes or so til warm then slowdown to a stoplights it threw in itself into neutral and wouldn’t shift in any gear and then have to wait til it cool down before it run again.
    Here what I’ve done to get my f430 back running again. I used x431 diagtool to bleed air from actuator, ediff and clutch drain. Test drove mostly on hwy shifted thru all gears for an hour or so to temp up then performed the selflearn and that’s it. So far so good now.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    We already tried that and fifth gear was being missed..we did the relearn cold again
    Although that worked for you and was hoping that it would have worked ( my thoughts last week and part of the on going diagnosis) for @f1canada it is just IMHO covering up another issue ..e.g. actuator sensors pentoimetes going bad or bad or even worse an actuator going (less likely)
  24. domo72
    domo72 Rookie
    Jan 9, 2019
    6
    ditetro davis
    Thanks for reply, my car will be going to dealer Friday morning. I'm new at this how do i pm just incase i need advice?
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    I sent you a PM. .look for it under conversations and reply whenever you need me
