F430 up-shift performance | FerrariChat
Discussion in '360/430' started by louismidiri, Jan 3, 2016.
  1. louismidiri
    louismidiri Rookie
    Jul 16, 2013
    10
    I 'think' I want to buy an F430 this spring. So I have started searching. Having never driven an "F"-type transmission I was disappointed with my 1st opportunity to drive a local F430. This car is owned by a gent who bought it as his 1st Ferrari. There was a very obvious lag between gear changes when up-shifting under power. Is this typical or does the transmission need mechanical attention to quicken the gear changes? Neither I or the owner know anything about the service history of this car.
    512TR
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    Lag between the time you flip the paddle, or lag between the start of the shift and the completion of the shift?
  3. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    Use the car in race, the changes should be quick enough and you will know all about them occurring. Make sure you are on the gas hard in every gear if you are going to try to assess how quick shifts are, and shift as the revs get close to the limiter each time. I don't think the 430 would disappoint anyone, unless maybe they have driven 458s or F12s with the dual clutch systems before it
  4. DIGMAN52
    DIGMAN52 F1 Rookie
    4,094
    Dallas Texas
    Philip C
    I tried to like the 430 but the F1 tranny got in the way. It still has the back and forth head bob of the earlier transmissions, unless you let off perfectly between shifts, and it was smoother. Had driven a 575 with it years earlier, and while the shifts are faster now, the smoothness I want was not.
    Ended up with a 2013 California with the DCT transmission, and all those issues went away. It is the best of both worlds. Stick it in auto in traffic, and paddle up when you want to play.
  5. nicholasn
    nicholasn Formula 3
    Nov 7, 2013
    2,250
    North Carolina
    Nicholas
    Find one with a gated manual trans...that way it will shift as quickly as you want it to! :D
  6. Mitch Alsup
    Nov 4, 2003
    9,728
    And never fail.......
  7. ph12
    ph12 Karting
    Jun 28, 2015
    178
    Los Angeles
  8. tazandjan
    39,169
    Takes a while to learn how to drive F1 smoothly. Those who say they tried it and did not like it usually never learned to shift properly.
    Many 360s and F430s have never had the F1 fluid changed or bled, either, and this affects shifting. Should be done every 3 years.
  9. 430b
    430b Karting
    Sep 12, 2015
    136
    There is a sensation of the shift but to me it feels so fast it's almost harsh. I remember it almost concerned me during my first 8,500rpm wot up shift. If you mean a delay at part throttle, it drives very much like a 3 pedal car imo. You need to select appropriate throttle input and rpm for smooth operation,
  10. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    You should probably drive both types of transmissions, if you can. The MT unit is becoming more difficult to find. It seems more and more rare each day.
    F1 shifting felt harsh to me as well. I didn't like it and felt like I was missing out on something.
  11. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    I agree. It took me a few weeks to "master" the F1 style of shifting. I'm having a new clutch installed this month and will have the entire system serviced.
    To the OP, my car will be available this spring if you don't find one.
  12. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    True--I noticed an improvement in shifting after flush and bleeding the F1 system--I didn't know it was sub-optimal before.
  13. louismidiri
    louismidiri Rookie
    Jul 16, 2013
    10
    Thanks guys and gals for the input on shifting sensation for the F1 equipped 430.
    Are there manuals out there providing guidance on the proper use of these transmissions? Is the info included in the owner's manual...I haven't the opportunity to see a user's manual yet?
  14. Rosso328
    Rosso328 F1 Veteran
    7,345
    Central FL
    Paul
  15. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    There's a big difference in how 05-07, and MY2008 onwards F1 systems drive and feel. I would recommend you try an early and a late car to find out for yourself.
    Also, there can be variation between cars.
  16. Cscat87
    Cscat87 Formula 3
    Oct 23, 2006
    1,220
    Long Island
    Chris
    The F1 system is pretty old school. Probably the thing I hate most about my 430. After driving a DCT trans car, you realize how bad the F1 really is. Shifts are slow and clunky, relative to the new cars. Recently had my F1 and E-gear fluids changed by the dealer, and it did not change anything.
  17. blackbolt22
    5,808
    Boca Raton, FL
    Mr. Anderson
    I agree. I didn't care for the F1 unit on my only drive with it but the DCT on the 458 is a dream.
  18. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    Just like with three pedal cars, they all shift differently. I driven one, let's call it "slightly neglected" that was a little slow to shift. Mine gets its annual fluid changes and it shifts way faster than I, and I'll bet you too, could using a clutch. It also allows you to keep both hands on the wheel which is a lot more important than you may realize - until you try it.
    No, it is not as fast as Porsche's PDK but it is fast enough. I never pull into the garage after a drive thinking "This car is fantastic - except for the shifting". Never.
  19. Cscat87
    Cscat87 Formula 3
    Oct 23, 2006
    1,220
    Long Island
    Chris
    Funny you mention that, as it is exactly what I think. I love everything about the car, except for the transmission. Though I also have a 911 Turbo S with the PDK that I am comparing it to. Planning to trade in the 430 for a 458 soon.
  20. louismidiri
    louismidiri Rookie
    Jul 16, 2013
    10
    I bought the car and am having it serviced at a local Ferrari dealership. The suggestion of selecting appropriate throttle input and rpm for smooth operation has me interested. My next task is to find the manuals, flashlight and leather folio. I have the owners manual. Where do I look for the rest?
