F430 Valve lifter problem | FerrariChat
Discussion in '360/430' started by Mats Andersen, Apr 26, 2019.
  1. Mats Andersen
    Mats Andersen Karting
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hi guys.
    Previous owner have had problem with a hydraulic lifter that doesnt operate properly.
    Only when warm it makes the classic tappet ticking noise. Not when cold.
    It has been so for years and about 40 000km. Tappets was replaced and revealed abnormal surface wear on 1 tappet.
    After replacing all tappets the problem persisted. So problem must be in the head is my theory.
    After I flushed the engine and put new oil rhe sound did indeed go away. I figured I had fixed it, but after som hours it came back.
    Did anyone experience similar scenarios?
    Oil pressure good. Power good. No error codes etc. Just the annoying sound. Especially after hard acceleration.
  2. mello
    mello F1 Veteran
    5,475
    CA Bay Area
    Steve
    I suspect oil pressure not up to spec. How is the oil pressure good? By looking at the gauge? The gauge or the oil pressure sensor could be off. I would double-check by using a professional oil pressure reader and setup.
  3. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hi yes the oil pressure is verified order and not the problem. :)
  4. tazandjan
    39,094
    Ferrari adds a special lubricant to the 612 and 599 to quiet noisy lifters. You might give their snake oil a try. Cheaper than anything else even if it is just a band-aid.
  5. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hehe. I have tried the Omega snake oil. No result. The immediate cure after the flush is kind of interesting. It would be bery interesting to inspect the head and check oil supply to the lifter.. hmmm
  6. Rifledriver
    36,939
    That presupposes the offender is in the same position. Do you have any proof to support that idea?
    Ferrari uses cheap hydraulic lifters. After about 70 years of use you would think everyone would know how to do it by now but Ferrari has proven otherwise.
    I am far more comfortable believing that out of 32 lifters it had 1 bad one and now out of 32 lifters it has another bad one. The odds are much better.
    Or that it is really something else.
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,769
    England
    Mark
    Lifter issues are generally down to lack of use, lack of regular optimum operating temp, but usually always the wrong oil. Don't add any crap to the oil because generally modern oils and fuels are fantastic.
    If the problem persists then my first port of call would be the cam lobes, just to check.
    brogenville likes this.
  8. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Thanks for the input guys.
    All the lifters on left bank was replaced by new ones and still the sound persisted. Onoe of the lifters had noticable wear, however the cam supposedly looked good.
    A cam lobe that would result in a sound like that would need to be severly damaged and so much so that anyone woul dbe able to tell. Supposedly it was looking very nice and similar to the other lobes.
    The sound is exactly the sound of a tappet that does not manage to keep contact with the cam lobe. A lobe that has been deformed just a tad would still stay in contact with a hydraulic lifter and hence would not make such a hammering mechanical sound.
    I am not confident about any theory other that something with the lifter..
    M
  9. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Hi - did you manage to find out the source of the issue? I have a similar problem - tappet noise around 2000-2500 rpm when the engine warms up. Interesting to hear about your finds... Thank you!
    Armando81 likes this.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,941
    Isle of man- uk
    What actually distributes the oil to them, is it just the oil pool in the head or is it supplied to each lifter. I have no idea by the way as never worked on engine with these lifters
  11. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hi, No problem is consistent and stable, but I have concluded that at some point I must pull the head and get to the bottom of it.
    Mike32 - the oil pressure is the force that keeps the tappet in touch with the cam so there is no lash clearance. A nice system when it works..
    On this paricualr tappet - when the oil is warm it does not longer maintain this constant tappet contact , hence the noise everytime the cam lobe comes around and close that clearance.
    Funny thing is that when oil is replaced, and system flushed it goes away for some time, perhaps a week. then it comes back again..
  12. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Thanks Mats. I'll probably do an oil service next week and will report!
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,941
    Isle of man- uk
    So changing the tappet would fix this problem ?
  14. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    914
    Georgia
    Mark Gronsbell
    To address a comment made by an earlier poster, Ferrari has not always used hydraulic tappets. If I recall correctly, the first use was on the 355. Prior cars had mechanically adjustable tappets both in the SOHC and DOHC engines.
    While this may not be helpful, at times an exhaust leak may make a ticking sound.
  15. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,941
    Isle of man- uk
    I watched an episode of Wheeler Dealers yesterday about a Mutsubishi 3000 V6 with hydraulic tappets, same problem you have and appears they are known for hydraulic tappet knocking. Originals only had 1 mm dia holes for the oil supply and they carboned up and knocking. Mod was new design with 3 mm holes . So either the holes are constricted or the oil supply to the set is not enough. ??
  17. tazandjan
    39,094
    In the olden days, we would clean Chevrolet hydraulic lifters with lacquer thinner to get all the build up out of the lifter body. In this case, it is only one out of 32 lifters causing a problem, which sounds more like a problem in the lifter bore or oil passage since new lifters did not cure it. You might talk to Daniel at Bradan since they pull the lifters for cleaning on every cambelt change and see if he has any ideas.
  18. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,004
    Cape Town South Afri
    Dave
    This was posted in the 355 section .
    Doctor Mark likes this.
  19. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Apologies for the late update.
    While doing the annual service, I turned out that it was indeed an exhaust issue.
    The Agency Power aftermarket exhaust manifolds/headers had a crack on one of the pipes on the right bank.
    A hairline crack separated the pile from the plate that attaches to the block.
    Warranty claim from AP should cover this as they have lifetime warranty.. Image Unavailable, Please Login
    JaguarXJ6 likes this.
  20. RedTaxi
    RedTaxi F1 Rookie
    3,334
    New Zealand
    Glen
    That's a great outcome. It's always amazed me how a header crack can sound just like a mechanical tappet noise. Even aftermarket headers can fail it seems. Quick question, do you still have the lower rear exhaust brackets fitted?
  21. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Yes, everything else is standard on the exhaust.
    I did have the Capristo brackets with the Mk2 OEM manifolds, but swapped them for stock when I installed the AP’s thinking it wouldn’t be an issue anymore..
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,941
    Isle of man- uk
    The exhaust can expand by 18 mm so the capristo brackets can cope with that
  23. RedTaxi
    RedTaxi F1 Rookie
    3,334
    New Zealand
    Glen
    Obviously it was. Whip those lower rear brackets off and leave them off. They are the problem. Often the brackets crack/break and people weld em up good and strong making the problem even worse.
  24. tazandjan
    39,094
    Snake oil would not have done much for that.
