Is the road wheel nut torque for F430 the same as a F355 ie 72 ft/lb .
I just typed in Ferrari 430 lug nut torque... http://www.discounttiredirect.com/direct/brochure/info/tmpInfoWheelTorque.jsp Hunter
since i have nothing real to contribute i'll just say that the F430 does not have lug nuts, it has bolts.
Newton meters are different the ft/lbs the conversion rate is .73756. Therefore 120NM is approximately 88.5 ft/lbs
how can there be so many different answers? the correct answer is 100Nm (74 lb-ft) +/- 10%, per the service manual. Image Unavailable, Please Login
Mousecatcher is on the money. How can this vary so much especially from a dealer? It certainly makes you wonder. Keep putting 85-100 lbs on those wheel bolts and you'll be looking for a bolt remover tool!
Not sure I trust that list since the 550 and 575M wheels are all interchangeable, they use the same lug bolts, hubs are pretty much identical in spec, wheel offsets are the same, but the list shows 100 lb-ft for 550s and 80 lb-ft for the 575M.
