F430 wheels on 456? | Page 2 | FerrariChat
F430 wheels on 456?
Discussion in '456/550/575' started by F129b, Nov 22, 2008.
  1. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Thanks for the heads up, Alfredo. I'm just sorry they gave you so much aggravation. Sounds like they should be banned from ebay, regardless of the names they use.
  2. tazandjan
    39,077
    Alredo- I just looked at your avatar in full size and that is one gorgeous car. That color really makes the lines stand out. Very impressive. Congratulations.
    Taz
    Terry Phillips
  3. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Well, I have tried first to have them work with me, to no avail, of course, then I have tried to alert e-bay of what kind of seller they are, but that is also something easier said than done and I came to the conclusion it is so by design.
    It is very misleading to look at their satisfaction rating and see that it is 99% positive, when in fact all the negative comments are simply not logged in.
    Anyway, if anyone has trouble with balancing those rims, I can point out what the problem was on mine.
  4. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Thanks, I do not have pictures with the 19" rims yet, but I will post them as soon as mange to get a few good shots.
  5. AB456
    AB456 Rookie
    Apr 20, 2019
    20
    California
    Alfredo Baccari
    After 11 years....what was the final result or decision for the tires?... I am considering 19R for my 456 and I really would like to know if anyone did them...
  6. tazandjan
    39,077
    Lots of owners with NF2s on their 456/456Ms. MPSS tires 255/35 19 F and 345/30 19 R with rear spacers. Narrower 19s can use stock 575M sizes of 255/35 19 F and 305/30 19 rear. V8 wheels not recommended. Too narrow.
    AB456 likes this.
  7. AB456
    AB456 Rookie
    Apr 20, 2019
    20
    California
    Alfredo Baccari
    Hi Tazandjan,
    thanks for the immediate replay...(after the 12 years -:)
    I was considering the 430 wheels with these tires:
    ( 245/35-19) Front - Rolling Diameter: 662.1 (-1.06%)
    ( 305/30-19) Rear, - Rolling Diameter: 665.6 (-1.06%) OR ( 295/30-19) Rear, - Rolling Diameter: 661, (0.15%)
    Are you saying that the 430 are NOT good for the 456?
    the 575M are too similar to the ones I have on... I also like the NF2s, but they are difficult to be found.
    Any suggestion?
  8. tazandjan
    39,077
    No suggestions, except the F430 wheels are an inch too narrow in front. So, no, I would not recommend them. Tires should work fine if you decide to do it. Handling is likely to be pushed (play on words) to more understeer with the narrower front wheels.
    white out and AB456 like this.
  9. AB456
    AB456 Rookie
    Apr 20, 2019
    20
    California
    Alfredo Baccari
    Hi Tifosi66,
    I am considering to change my wheels to 19 for my 1995 456. I like 2 models, really similar looking, the 430 and Novitec NF.
    I read all great notes on this chat and I was wondering if:
    1. Are there other wheels that should I consider similar looking with a better fit for my car? (I don't like the 550-575-610...)
    2. Do you know the specific Novitec that could fit with 456?
    3. Considering that the best will be without spacers, but it seems impossible, which wheel would you use (obviously with the right tires)?
    Ciao
    A
  10. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,893
    MO
    Omar
    #35 Auraraptor, Aug 17, 2020
    Factory F430 Wheels are too narrow in the front! They are only 7.5in wide and not rated for the weight of a front engine GT.
    NF2 wheels fit with a spacer in the rear.
    Wheel choice is personal. My favorite in no particular order:
    OEM 19in modular
    Hamann PG2 or PG3
    HRE P107 (no spacers needed)
    NF2
    BBS Fi-R (?)
    From a strictly performance standpoint the best would likely be either HRE or BBS Fi-R, as they are both forged and lighter/stronger than OEM. Neither should require spacers either.
    There is a gentleman selling his Fi-R wheels in the classified section; I know the rears fit without the need for any spacers. I never worked out the numbers for the front but they would most definitely not require spacers.... However the very low offsets may be too aggressive and stick out? Sorry I’m not as familiar with range of offsets 456 can use.
    AB456 likes this.
