F430 Window Controls | FerrariChat
Discussion in '360/430' started by corvettefever, Nov 26, 2016.
  1. corvettefever
    corvettefever Rookie
    Dec 31, 2013
    43
    Seminole Florida
    Bob Patrick
    Passenger side window control pushed through dashboard plate. Anyone else experienced this problem? How do I gain access to the area behind the bezel? Plastic tabs on switch appear broken by looking through hole in the plate. 2007 Coupe
  2. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    You need to remove the center F-430 dash plaque with the small 4 Allen screws then remove the radio with the radio removal tools that hopefully are in the pouch with your books. Once that's done you will see 4 Phillip head screws you will have to remove and then the center Can be removed. The switches are attached with 2 small screws per switch. Hopefully the screws came loose and it's nothing more.
  3. Dicecal
    Dicecal Formula 3
    1,859
    Phoenix, AZ
    Rob
    #3 Dicecal, Nov 26, 2016
  4. corvettefever
    Dec 31, 2013
    43
    Seminole Florida
    Bob Patrick
    Thanks Dominic and Rob for the info.
  5. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    Any other method in removing the radio if the radio removal tools are missing?
  6. Ferris Bueller
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    Yes
    If you use metal file that swivels out from the back of a larger nail clippers that works too. I bought 2,of them at CVS.
    I saw that trick on You tube and it worked for me. Of course I found the radio removal tools in my glove box afterwards!
  7. corvettefever
    Dec 31, 2013
    43
    Seminole Florida
    Bob Patrick
    Once I returned to Florida, I decided to follow the advice of Dicecal and Ferris Bueller, and attempt to check out my window switch. So after tuning in some good old time rock and roll on the garage stereo, gathering tools, and a cold adult beverage, I removed the radio. This gave me access to the window switches without removing the dash panel. I can't imagine how hard my buddy had pushed on that switch, but it had simply popped through the opening. I snapped it back in place, replaced the radio, and the job was finished before the beverage!! Thanks again guys, and Merry Christmas!
