F8 - beeping noise | FerrariChat
F8 - beeping noise
Discussion in '458 Italia/488/F8' started by socalferrari, Oct 16, 2022.
  1. socalferrari
    socalferrari Rookie
    Feb 28, 2017
    29
    Orange County, CA, USA
    Hi all,
    Im new to F8 ownership. Brand new F8 with 54 miles. Came home to a beeping noise that occurs every 60 seconds. Single beep.
    Battery tender has been connected to the car since delivery. Light on the tender is green. No other lights are on the car.
    All doors are closed. I tried disconnecting the tender and the beeping persists.
    Any ideas what this could be and how I can get rid of it? The issue just started. Could it be a bad battery?
    thanks again for your help.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    Did you park it in neutral or with the hand brake off for example ?
    As a last resort you could go all twentieth century and RTFM
  3. Viperjoe
    Viperjoe F1 Rookie
    RTFM - I just got that and literally LOL.
  4. ScottS
    ScottS F1 Rookie
    2,937
    Winter Park
    Scott S
    Turn signal on or similar operational issue. Something.
  5. subalou1
    subalou1 Karting
    Nov 12, 2009
    66
    NY
    Did the beeping stop? I noticed the beeping today too (took me a while to figure out the beeping was coming from the car). It hasn’t done this in the past. Nothing is left on. It’s a single beep coming from the rear of the car every 30 seconds. I started the car, moved it around a bit and the beeping continued with the engine running (battery was reading 13.4v on the dash). I’m letting it chime away right now, if the weather clears up I’ll take it out later.
