F8 brake-squeal like sound at all speeds (25k km unit) | FerrariChat
Discussion in '458 Italia/488/F8' started by lucasglory, Jun 16, 2024.
Tags:
  1. lucasglory
    lucasglory Rookie
    Jun 9, 2024
    14
    I'm at the end of my wits and the sound is driving me insane. It gets louder when turning.
    Car is a head turner for all the wrong reasons. Bought it 2nd hand and the issue became apparent maybe three days into the ownership.
    I sent the car to the Ferrari service center, and they told me that no unusual sound was detected.
    You be the judge, video attached. FYI I'm not even touching the brake pedal, other than on the ramps down.
  2. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    I don’t hear anything other than some weird clunking sound and the tires squealing on the smooth concrete…. If you’re talking about the VERY high pitched squeak (like a whistle), that’s not the ‘brake squeal’ that ceramic brakes do…. THIS sounds like a rock or debris wedged in between your pads and rotors… blow them out with compressed air or power washer or both.
    AD211 likes this.
  3. lucasglory
    lucasglory Rookie
    Jun 9, 2024
    14
    Yes I'm referring to the very high pitched squeak
  4. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
    Could be debris, could be glazed pads. Squeal happens when brake pedal is not depressed. When you touch pedal slightly if brake noise increases I’d vote stone/debris, if it goes away I’d go with an issue with the pad surface. If the latter go do some hard braking (but do what Todd suggested and check for debris first)
    Ps. Can you tell whether it is occurring on 1 or more corner? 1 corner = debris, more than one = pad issue
  5. lucasglory
    lucasglory Rookie
    Jun 9, 2024
    14
    The noise increases if I touch the pedal slightly. In practice, what would be the best way to clean the brakes out? Do I need to take the wheels off?
    I'm not 100% sure if it's one corner, but definitely coming from the front of the car. Will check.
  6. Mrpseudonym
    602
    Sydney, Australia
    yes you'd need to take the wheels off, but if you get the car up on a jack or hoist and rotate each front wheel by hand you might get more clues before you take the wheels off
    Viperjoe likes this.
