F8 exhaust options. GPF delete | Page 10 | FerrariChat
Discussion in '458 Italia/488/F8' started by LMH, May 23, 2020.
  1. Mortarion
    Mortarion Karting
    Jun 6, 2020
    75
    New Zealand
    Jase
    I believe it’s a novitec exhaust system but the car has been tuned
  2. red passion
    red passion Formula Junior
    Mar 4, 2012
    793
    Hockenheim, Germany
    Decent F8 exhaust incl. GPF
    stavura and mdrums like this.
  3. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Prefer Kline or Novitec sound/pitch. Seems a little muted, not as high pitched as I would like.
  4. red passion
    Mar 4, 2012
    793
    Hockenheim, Germany
    Sure, however this has the GPF still in place and for that it sounds quite decent. I think it's the only after market solution I came across which hasn't the GPF removed.
  5. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    I was not aware that any aftermarket exhaust would include the GPF. Maybe for those that don't want to eliminate it or those is Europe?
  6. Mortarion
    Mortarion Karting
    Jun 6, 2020
    75
    New Zealand
    Jase
    If you don't want to install CEL delete module or tune the ECU It would be the logical choice. I have the X pipe from Fabspeed that deletes the center resonator and has a noticeable sound improvement which i will use till I decide to get whole system installed after warranty expires.
    Petrolhead#32 and GT2goneF like this.
  7. red passion
    Mar 4, 2012
    793
    Hockenheim, Germany
    I wasn't aware either. But for those in Europe that's good news to have a "more legal" option to make the F8 sound decent.
    GT2goneF likes this.
  8. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    I think these guys were thinking ahead and at the untapped Europe market. Aftermarket exhaust with GPF, brilliant. Now watch the liberals there go after the aftermarket exhaust anyway for some other stupid reason, even if it meets emissions criteria. I had the same done with my GT2 and it passed emissions but when they found out that it had an exhaust on visual inspection, they did not want to pass it. What sort of BS is that?!!!
    stavura and Drson like this.
  9. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
    mdrums likes this.
  10. Apatel219
    Apatel219 Rookie
    Nov 6, 2016
    15
    I just ordered the novitec one for my F8 hopefully it works. Did your still sound good with it on?
  11. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    It will workm regardless of valved or non valved. However, valve-less will be slightly louder than valved. Both will be louder than stock. And not obnoxiously loud.
    OSUferrari likes this.
  12. Marc Goldstein
    Marc Goldstein Karting
    Jul 3, 2018
    115
    Westchester NY
    Briarcars
    Any exhaust updates. Anyone hear if Capristo fixed their dash light fault. I am thinking of doing Novitec power optimized w/out flap regulator and Novitec N-Tronic. Does anyone know what the benefit of the Novitec Switch Tronic is and should I add that in also? Has anyone done this set up and had any dash fault lights and does anyone know if any or how much HP will be achieved? Is Novitec bullit proof so far?
  13. Dicecal
    Dicecal Formula 3
    1,869
    Phoenix, AZ
    Rob
    Novitec seems to be the most bulletproof, the switchtronic will allow you to manually control the value operation with cockpit button or remote. I’ve got the Kline system on order, but their OBD port plugin leaves a lot to be desired. If you go with the no flap (no valves) you certainly don’t need the switchtronic.
    GT2goneF and Marc Goldstein like this.
  14. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
    I had Excel auto in Boca Raton straight pipe my 2020 F8. Took the GPF and cats out. Loud on cold start but calms down to an amazing sound in about 60 seconds.
  15. OSUferrari
    OSUferrari Formula Junior
    Dec 13, 2015
    631
    Denver CO
    Video with sound? Would love to hear it.
  16. Marc Goldstein
    Jul 3, 2018
    115
    Westchester NY
    Briarcars
    How long have you had it on and have you had any lights or defaults?
  17. Marc Goldstein
    Jul 3, 2018
    115
    Westchester NY
    Briarcars
    Do you need a tune like Novitecs N-Tronic for the Kline exhaust to avoid Lights and Sensor faults? If so does Kline make it or would you use Novitecs?
  18. Marc Goldstein
    Jul 3, 2018
    115
    Westchester NY
    Briarcars
    Sorry, just looked up Kline and they do make their own, thats what you meant by OBD port plugin. Wonder if you could use the Novitics unit w/ Kline exhaust?
  19. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
    threw at catalytic converter overheat code once but has no cat. They adjusted and fixed it.
  20. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
  21. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
    F8 straight pipe
  22. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
  23. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
  24. ennismd
    ennismd Rookie
    Apr 2, 2021
    8
    Ennis Plastic
  25. Dicecal
    Dicecal Formula 3
    1,869
    Phoenix, AZ
    Rob
    No the Novitec Techtronic OBD plugin clears the codes, I would use it with the Kline system except Novitec charges 2x the price if you don’t buy it at the same time with a Novitec exhaust system.
