F8 exhaust options. GPF delete | Page 21 | FerrariChat
Discussion in '458 Italia/488/F8' started by LMH, May 23, 2020.
  1. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    Shaddup both of you [emoji23]
    And yes, I am scared. I want to do it so badly but remember, I’m the poor owner who can’t afford to fix this thing if it breaks.
    And if I ever saw a CEL, I’d immediately wanna sell it. Like INSTANT.
  2. mkraft3003
    mkraft3003 Formula 3
    2,382
    Tampa, Fl
    Todd, small piece of electrical tape will solve the CEL. I guarantee you will never see it again!
  3. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,993
    St. Louis, MO
    Eric
    leave that ***** on long enough and it will burn out. problem solved
  4. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Good Lord - just vomited a little
    mkraft3003 likes this.
  5. Eric C
    Mar 20, 2009
    10,993
    St. Louis, MO
    Eric
    The sooner you realize that these are just dumb cars, the more happier you'll be with it.
  6. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,217
    Midwest
    Ivan Drago
    btw the CEL for this is not because there is actual damage going on, its just because the cars tampon has been ripped out and it wants it back
    Deezul_812SF and Eric C like this.
  7. mkraft3003
    2,382
    Tampa, Fl
    It’s more of a “recommendation” to check the engine. When it catches on fire or starts smoking is the real signal to pull over and take it to the dealer. :cool::cool:
    RoadRonin, Eric C and Ivan Drago like this.
  8. Ivan Drago
    Jul 14, 2021
    1,217
    Midwest
    Ivan Drago
    Todd will never sleep again after reading this.
  9. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    one sec, making calls to find some of Florida's finest street drugs.... I'm curled up in the corner in fetal position, sucking my thumb and shaking right now.
    .... and I don't believe the 'light coming on isn't harmful' theory. If it comes on, there's a problem and there are no 'problems' that don't cause some kind of damage.
  10. Hunter911
    Hunter911 Karting
    Mar 8, 2012
    200
    Toronto, Canada
    Turbos burning out? It's a simple cat-back exhaust. I've done this on 15+ cars over the years, have never had an issue. Highly doubt letting the car breathe a little better is causing damage.
  11. Eric C
    Mar 20, 2009
    10,993
    St. Louis, MO
    Eric
    non car people should just stay non car people. don't yall have other hobbies?
    maybe knitting or protesting
    Deezul_812SF and Hunter911 like this.
  12. Ivan Drago
    Jul 14, 2021
    1,217
    Midwest
    Ivan Drago
    It depends on what you mean by problem. They designed it to comply with EU air regulations, just like Porsche has done. When you remove the GPF, the ECU knows it's missing, so it alerts you. Porsche at least had the decency to have the ECU not throw a code in the US
    Deezul_812SF and mdrums like this.
  13. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,330
    Tampa FL
    I never bought extended warranty on my 488GTB... did 9500 miles on the car never any issues.
    Deezul_812SF, Hunter911 and 05F430F1 like this.
  14. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,330
    Tampa FL
    F8 turbos are not the same as 488GTB/Spider or even Pista turbos. F8 received a "more durable" turbo. However if you treat the car properly and do not run th turbos hot and then shut th car off 488 - Pista Turbo's are fine.
    Deezul_812SF and 05F430F1 like this.
  15. Eric C
    Mar 20, 2009
    10,993
    St. Louis, MO
    Eric
    Yall are some goofy sumbitches
    mdrums, 05F430F1 and Ivan Drago like this.
  16. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,498
    AUSTRALIA
    ANGELO
    Please dont compare the F8 to the Pista. The Pista sounds great just out of the factory. Pin the valves and its even better. Have an aftermarket exhaust , hum , not needed.
    Pista pin valves = yes
    F8 = cant pin the valves = has GPF.
    In this world many people change OEM settings. Wouldnt do it on a car so expensive unless you dont have to worry about the loss if it blew up.
    mdrums likes this.
  17. MANDALAY
    May 23, 2013
    14,498
    AUSTRALIA
    ANGELO
    IMO I dont believe everyone allow their turbo engines to warm up and then cool down before shutting off. I do.
    mdrums likes this.
  18. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,330
    Tampa FL
    Same here
    MANDALAY likes this.
  19. Ivan Drago
    Jul 14, 2021
    1,217
    Midwest
    Ivan Drago
    If you do complete novi exhaust and the other mods like I said then both don’t have GPF or pinned valves (can be valved or not)
  20. uniqueMR
    uniqueMR Formula Junior
    383
    Mr. O
  21. Eric C
    Mar 20, 2009
    10,993
    St. Louis, MO
    Eric
    Deezul_812SF likes this.
  22. Mortarion
    Mortarion Karting
    Jun 6, 2020
    75
    New Zealand
    Jase
  23. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Noticeable sound improvement? Like seriously, much better or just a tiny bit louder?
  24. Mortarion
    Mortarion Karting
    Jun 6, 2020
    75
    New Zealand
    Jase
    There's an improvement and it will fill that void till you decide to go full exhaust setup. I installed the X pipe soon as I purchased the car so don't have much experience hearing it stock. Would be much better if can pin the valves or get a controller.
    Cigarzman likes this.
  25. Dsald
    Dsald Formula Junior
    Mar 12, 2022
    277
    Chris Johnson
    I just drove the car with novitec exhaust and 200 cell Kline cats. Sounds great, and probably as loud as I would want it.
    Might add the novitec valvetronic to make it more quite in the neighborhood.
