F8 exhaust options. GPF delete | Page 4 | FerrariChat
Discussion in '458 Italia/488/F8' started by LMH, May 23, 2020.
  1. cpiguy
    cpiguy Formula 3
    2,163
    Westlake Village, CA
    Arnie Friedman
    I’m very very happy with the car, including the way it sounds. It will never sound like my 458 or an Aventador, but the car is exponentially better in every other way. Being able to keep the valves open is a little icing on the cake.
    Viperjoe, SECRET, Caeruleus11 and 9 others like this.
  2. SoCal to az
    SoCal to az F1 World Champ
    15,159
    Arizona
    And that in a nutshell is what the sound debate is all about. Sound is not as good but in every other measure the car is superior. Congrats Arnie!
    SECRET, Caeruleus11, uhn2000 and 3 others like this.
  3. cpiguy
    cpiguy Formula 3
    2,163
    Arnie Friedman
    Thanks man!
    SECRET, uhn2000 and LMH like this.
  4. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,843
    AUSTRALIA
    ANGELO
    The only one thing that confuses me is when the valves were pinned you had a cel light but with the Capristo controller you don't. To me that doesn't make sense. I wonder what the dealer did to pin the values. This issue isn't observed with the 488 or Pista.
  5. cpiguy
    cpiguy Formula 3
    2,163
    Arnie Friedman
    I agree, which is why I asked for confirmation in writing. This was the response from Capristo when I ask for an explanation.
    “Our kit has a “piggyback” electronic pass through. The module is “in line” in the harness chain so the computer never gets a code that valves are not functioning. Whereas pinning them open you have the electronics getting no feedback and a change in vacuum pressure. Our module can then override factory function signal to keep valves open at all times as default and just use remote to go back to OEM control“
    FLU, SECRET, Caeruleus11 and 3 others like this.
  6. MANDALAY
    May 23, 2013
    14,843
    AUSTRALIA
    ANGELO
    Ok , bit over my head on that answer , but if it works , God Speed. Wonder if all the other suppliers will do the same . Enjoy you car mate.
    SECRET likes this.
  7. Cigarzman
    Cigarzman F1 Veteran
    That’s just awesome, thank you for figuring this out for the rest of us. ! Score 1 for the home team.
    SECRET likes this.
  8. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    Basically the controler tells the system everything is ok but you can open the valves the whole time and it still tells it all is ok, it lies to the sensor so you can do what you want
    SECRET and uhn2000 like this.
  9. buddyg
    buddyg F1 Veteran
    6,456
    Naples, FL
    Buddy
    Arnie how much was the capristo and did the dealer do the install?
    SECRET likes this.
  10. cpiguy
    cpiguy Formula 3
    2,163
    Arnie Friedman
    Hey Buddy. It was around $1600 installed. And yes, I bought the package from my dealer.
    SECRET likes this.
  11. buddyg
    buddyg F1 Veteran
    6,456
    Naples, FL
    Buddy
    So you would think it wouldn’t effect the warranty, what did the dealer say about that?
  12. cpiguy
    cpiguy Formula 3
    2,163
    Arnie Friedman
    Never asked. It does make me feel comfortable that they did it though.
    PTG1 likes this.
  13. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,149
    If you can’t beat em , join em.
    What if instead of trying to defeat the GPF, one used a lighter and less sound reducing muffler?
    Could that improve the exhaust music?
  14. MANDALAY
    May 23, 2013
    14,843
    AUSTRALIA
    ANGELO
    Even better would be a sound engineer working with one of the companies e.g Kline. But I guess they all take the easier route and just give an option with muffler delete.
    Doesn't help also with distributors like Vivid not actually having any videos and stating what the equipment is.
  15. Dicecal
    Dicecal Formula 3
    1,871
    Phoenix, AZ
    Rob
    Eurospares finally has parts diagrams for the F8 on their website:
    Just realized the GPF is integrated into the silencer (muffler). So it seems you could just replace the entire assembly (Like the Novitec valved exhaust) and leave the OEM CAT pipes in place. Might be a good starting point instead of replacing the upstream CAT pipes as well. Of course you’d have to add the “Techtronic” plug in to avoid CELs. Will be interesting to see more vendors solutions as they come to market.
  16. MANDALAY
    May 23, 2013
    14,843
    AUSTRALIA
    ANGELO
    I don't believe there is any reason not to believe that the diagram above is not correct.
    Having said that it can be clearly seen that there is ZERO control ECU wise with the GPF its all BS
  17. Dicecal
    Dicecal Formula 3
    1,871
    Phoenix, AZ
    Rob
    #92 Dicecal, Jul 17, 2020
    That appears to be the case, so you may be able to replace the rear silencer and GPF with a valved system and maybe not have any CELs?
  18. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    This sounds like this could be a good option [emoji1360]
  19. ferrarifanatic25
    ferrarifanatic25 Formula Junior
    Apr 9, 2009
    889
    OC
    I wonder why Ferrari went with no silencers on the Roma but kept them on the F8? You would think the F8 is supposed to be the more aggressive sounding car given its place in the sports car lineup rather than the GT lineup? Maybe they dumbed it down on purpose to ensure the SF90 would produce a more aggressive sound?
  20. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    I think the answer is this. They deleted the resonators, but not the actual mufflers. The F8 does not have resonators. I peaked in under the Roma, and there's definitely a box. The GPF is up front so it was not that. Sometimes dealers will say the oddest things to make things more attractive. If they on purpose did something to make the F8 sound less aggressive, why the hotpipe, and why on earth then not make the entry level car that is supposed to be less frightning even quieter? I've heard them both and to say that the F8 is less aggressive and more quiet is B.S.
    ferrarifanatic25 likes this.
  21. Dicecal
    Dicecal Formula 3
    1,871
    Phoenix, AZ
    Rob
    Just got off the phone with a Novitec North America rep and he claims you will have to use the Techtronic plug with the valved exhaust to keep the CELs away...
  22. ferrarifanatic25
    Apr 9, 2009
    889
    OC
    Sounds like the typical dealer sales pitch. I haven’t heard the Roma in person yet so I’ll take your word for it.
  23. MANDALAY
    May 23, 2013
    14,843
    AUSTRALIA
    ANGELO
    So both Capristo and novitec both stating they don't throw a cel. Well IMO just having control of the valve shouldn't. Cel wil depend if you change the cats and to what level. Ive seen 200 not affect cel but 100 and decat do hence why they put extensions on the O2 sensor bung and state you need a tune.
    My opinion is that all the companies that have valve control you wont get a cel. Also going buy the diagrams You can do what you want like a 488 GTB or Pista.
    Gh21631 likes this.
  24. OSUferrari
    OSUferrari Formula Junior
    Dec 13, 2015
    631
    Denver CO
    Thanks for posting Arnie. I am ordering this on Monday. So glad you gave it a try and shared with all of us.
  25. pvgtv
    pvgtv Rookie
    Sep 5, 2013
    39
    Los Angeles, CA
    AK
    I should’ve checked here before asking the dealer to unplug the lines basically right after taking delivery. Never had issues doing this on my other Ferraris but sure enough CEL came on after 80 miles of driving. Sound was SO unbelievably disappointing without the valves open that it is difficult to describe. And conversely improved to a very happy place with them open. My dealer has always done right by me and they are looking into solutions. Anyone have issues w Capristo yet? Any input much appreciated.
