F8 - F8 lift system | FerrariChat
F8 F8 lift system
Discussion in '458 Italia/488/F8' started by Rearden, May 16, 2022.
  1. Rearden
    Rearden Rookie
    May 1, 2018
    8
    Portland, OR
    Alexander Aginsky
    Is it possible to keep the lift system up after the engine is turned off on the F8?
  2. Viperjoe
    Viperjoe F1 Rookie
    Yes but it will slowly creep back down.
  3. Rearden
    Rearden Rookie
    May 1, 2018
    8
    Portland, OR
    Alexander Aginsky
    How do you do it?
  4. Prox
    Prox Rookie
    Jul 24, 2021
    28
    You leave it up when turning off the engine. But it will slowly move down and by slowly I mean like in a minute it will be fully down again
  5. Rearden
    Rearden Rookie
    May 1, 2018
    8
    Portland, OR
    Alexander Aginsky
    Yes, I noticed that. But there should be a way to keep it lifted up permanently after the engine is off, like if you park over a curb and want to keep it lifted up until you pull out of the parking spot.
  6. Chizz
    Chizz Formula Junior
    995
    Atlanta
    The lift system will automatically re-engage when you restart the car if you turn the car off with it on.
    Rearden likes this.
  7. Rearden
    Rearden Rookie
    May 1, 2018
    8
    Portland, OR
    Alexander Aginsky
    But is there no way to keep the nose lifted the entire time that the engine is turned off?
  8. Viperjoe
    Viperjoe F1 Rookie
    No there is not.
  9. And I don't think you'd want it to, either.
    It would put too much stress on the system and shorten its lifespan.
  10. Chizz
    995
    Atlanta
    I’m sorry bro no there is not to my knowledge
  11. Kai0705
    Kai0705 Rookie
    Jul 30, 2021
    5
    Kai Zhu
    Yes, you could if you follow the next steps
    1: Keep the nose lifted and DO NOT turn the engine off.
    2:Open the door and get out of the car with the car key.
    3: Turn off the engine while you and your car key are outside the car.
    Then, your nose would keep lifted, until your next drive.
    However, I suggest don't use this trick as your daily parking method, just as Ipsedixit stated-
