F8 P101E Code - Help ! | FerrariChat
Discussion in 'Technical Q&A' started by beardp, Apr 8, 2024.
  1. beardp
    beardp Rookie
    Dec 1, 2023
    4
    Paul Beard
    Just took delivery of a CPO 2020 F8 from San Diego Ferrari. Delivered Friday April 5th.
    Less than 2 days and on the delivery tank of Gas it throws a CEL !
    I had the car shipped. I am in Northwest Montana. Nearest dealer is in Seattle.
    I was able to clear the code, but it just happened again.
    I asked the salesman at San Diego for help but, of course, no reply.
    Does anyone know what code this corresponds to? I'm hoping that I can wiggle some sensor connector(s) and fix it.
    Thanks you
  2. beardp
    beardp Rookie
    Dec 1, 2023
    4
    Paul Beard
    I took most of the intake components off. It looks like the MAF sensors have been swapped. The tell is the munted MAF sensor fasteners.
    This car has only 3000 miles !
    I have a complete Ferrari shop history printout. I don't trust carfax - now I'm starting to mistrust the Ferrari workshop reports - nothing more than an oil change.
    The frustrating part: I am absolutely delighted with the performance - completely, utterly blown away. I have been a 911 nut and always thought Ferraris were handbags. Eating a flock of crow - I admit that this F8 completely destroys my 992 GT3RS (which was way more expensive).
    I have cleaned the MAF sensors and the connectors. Hope my hunch on the code is correct.
    05F430F1 likes this.
  3. mikey64
    mikey64 Formula Junior
    572
    TN
    mikey
    Wow. Good luck!
  4. windsock
    windsock Formula 3
    1,153
    This is either a exhaust backpressure issue or a purge valve circuit issue. I can log in and look closer with the last 6 of vin if you want to PM me that. I suspect this may have a Novitec bypass valve system on it eliminating the soot filters. This should come with a piggy back module that plugs into the DLC port to reset the code on every key cycle. I am out of Seattle area but we service 8-10 cars out of Montana area, Missoula, Flathead lake and Boseman areas. Reach out if we can help remotely.
