F8S carbon fiber projects | FerrariChat
Discussion in '458 Italia/488/F8' started by dtandy, Jun 30, 2023.
  1. dtandy
    dtandy Rookie
    49
    Huntsville, al
    I thought I'd share a video and some images of my F8 Spider project. I machined a mold on one of my CNC machines for a carbon fiber gas cap cover for my F8S. The cover is made of a plain weave carbon fiber, chopped carbon fiber, epoxy resin, and stainless steel threaded inserts used to mount the cover to the pivot. I'm happy with how it turned out. I have about 2000 miles on the car since mounting the cover and so far so good.
    The epoxy is added to the part using a resin transfer molding process that pulls a vacuum in the mold cavity and draws resin through the carbon fiber reinforcement. The part comes out of the mold with an excellent surface finish.
    Next up is a carbon fiber brake pedal and a one-piece carbon fiber engine cover.
    https://www.youtube.com/shorts/thJZSyHUR2w
    Level7 likes this.
  2. SD455TA
    SD455TA Formula Junior
    Well done!
  3. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,644
    SF Bay Area, CA
    Ruben
    The gas cap looks great, congrats! I’m curious as to why you’d want a carbon fiber brake pedal (other than the aesthetics)… I’d be concerned that it could crack in a panic stop and/or spirited driving. :eek:
    Either way, great job and best of luck!
  4. dtandy
    dtandy Rookie
    49
    Huntsville, al
    Thanks. The brake pedal will look pretty cool. I'll test it up to a significant force in my facility to include fatigue testing. I have no doubt carbon fiber designed properly will be plenty strong enough. The more challenging piece is the engine cover as it requires mounting points for the air springs and hinges.
    Il Tifoso likes this.
