Fabio 010101 vs 010102 headers | FerrariChat
Discussion in '456/550/575' started by Auraraptor, May 30, 2020.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,979
    MO
    Omar
    Hi I’m trying to understand the difference between the two Fabio headers for 575s.
    Is it a early/late model issue or air recirculation add on or something else.
  2. tres55
    tres55 F1 Rookie
    3,572
    Canada
    When I ordered mine for my 550 it was something to do with the EGR or emissions...I chose to remove it if I recall correctly.
  3. Auraraptor
    Sep 25, 2002
    13,979
    MO
    Omar
    Thank you.
    If I recall correctly, you have not had any issues with warning lights either, despite removing the EGR? How did you go about removing the EGR system?
  4. ifeelfree0
    ifeelfree0 Formula Junior
    604
    Medina, Ohio
    Dan
    Can I get clarification on what is happening? I have a very late 575 and have Fabio's complete system and have been getting errors from Day 1. Replaced two rear sensors and now am getting an "unidentified error code". I will be getting with Fabio on it shortly however any background info will help. He has been very supportive throughout this process... My mechanic is very skilled albeit frustrated and doesn't want to start replacing ignition cables or injectors prematurely. Car seems to be running fine. Much appreciated.
  5. Auraraptor
    Sep 25, 2002
    13,979
    MO
    Omar
    Which version did you install?
  6. ifeelfree0
    604
    Medina, Ohio
    Dan
    That may be the $1m question. I willl check my invoice and let you know. I purchased it about 2. 1/2 yrs ago
  7. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    I believe the difference is 010201 headers have attachment ports for the secondary air injection system, 010202 headers do not. The secondary air injection system activates when you start a cold engine to help heat up the cats.
  8. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Fabio has 2 versions of manifolds for 550/575
    - with sec air system
    This system is good for 550 and 575 without faults
    - without sec air system
    This system runs without faults only at the 550
    He said that the 575 without sec air system causes faults, so I believe that he don't sell the system without sec air to any 575 owner.
    Only at the 550 this system runs without any faults which I can guarantee because I have this installed since 1,5 years without any problem.
    Daniel
    Auraraptor and F456M like this.
  9. ifeelfree0
    604
    Medina, Ohio
    Dan
    It was confirmed for me that on the 575 I received the correct header, as stated above. He only sells that one type for a 575
  10. brogenville
    brogenville Formula 3
    2,268
    Robin
    It’s possible now to run a 575 without secondary air injection and no faults. Just needs some code tweaking in the ecu firmware.
  11. Auraraptor
    Sep 25, 2002
    13,979
    MO
    Omar
    Who offers that service?
  12. Dm993tt
    Dm993tt Rookie
    Aug 19, 2019
    38
    David
  13. brogenville
    2,268
    Robin
    Send a PM to 360Trev on here, or better yet email AV Engineering, as they have partnered with him. He’s written his own software to do this.
  14. tres55
    tres55 F1 Rookie
    3,572
    Canada
    That would make sense as to why I went without sec air system on my 550. I think I recall him telling me that it is fine on 550 as well.
