For Sale - Fabspeed catby pass / test pipes - 458 Unleaseh the F1 V8 sound | FerrariChat
For Sale Fabspeed catby pass / test pipes - 458 Unleaseh the F1 V8 sound
Discussion in 'Ferrari Parts & Collectibles' started by Lethal, Feb 17, 2021.
  1. Lethal
    Lethal Karting
    93
    Miami
  2. Lethal
    Lethal Karting
    93
    Miami
    Replaces the restrictive factory catalytic converters with straight pipes for maximum flow, performance and sound.
    SOUND:
    Removing the factory catalytic converters from your 458 will unleash a lot of sound from the 458's V8. Expect a much more aggressive exhaust note with these Cat Bypass Pipes.
    FEATURES:
    • Fits all Ferrari 458 Italia / Speciale vehicles (2010-2015)
    • Fabspeed's Primary Cat Bypass Pipes replace the restrictive factory catalytic converters with much less restrictive straight-through pipes for maximum flow and performance
    • Direct bolt-on replacement for the heavy factory catalytic converters
    • Adds an aggressive exhaust note for exotic high-performance sound
    • Constructed from mandrel bent T304L stainless steel
    • Simple DIY bolt-on installation, no cutting or welding required
  3. Lethal
    Lethal Karting
    93
    Miami
    Cat delete pipes Price reduce, 1250 shipped.
  4. Fv81587
    Fv81587 Karting
    Aug 18, 2018
    125
    Novi, Mi
    Frank Valeri
    Would these set a CEL and require a mini cat in the downstream O2 sensor?
    Frank
  5. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,140
    Fort Washington, PA
    John S
    Frank,
    Yes, You will need to run an O2 Spacer in order to avoid the CEL.
  6. Hunter Shaw
    Hunter Shaw Rookie
    Jun 22, 2020
    7
    Hunter Shaw
    Hey is this still available?
