Fabspeed Header problems | FerrariChat
Discussion in '360/430' started by lethetton, Jun 11, 2016.
  1. lethetton
    lethetton Rookie
    Oct 11, 2015
    26
    Houston, TX
    Lee Ethetton
    I had my 2007 F430 Ferrari headers replaced by Fabspeed headers about 2.5 months ago and I have had nothing but problems with them. They were replaced by my mechanic in Houston that has been working on my cars for over 10 years and who I highly trust and respect. The first issue was that the oxygen sensors had to be adjusted so that the computer would sense the same amount of oxygen that the factory headers did. We thought that resolved the problem, but I relocated to NC shortly after that and now I get an engine light every time I use the car. The only solution is to turn of the master power switch each time and reset the computer. Then start the car the next morning and run it without touching the throttle for 5 minutes. It runs fine that day and the next time I use it.
    The second time I use it, I have an engine light. When a computer is connected to the car, it shows no errors. If I were to have a real issue, I would not know it. I sincerely regret purchasing the Fabspeed headers.
    Has anyone else had these issues?
  2. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #2 ferralc, Jun 11, 2016
    when you say "the oxygen sensors had to be adjusted so the computer would sense the same amount of oxygen" do you mean you installed 02 extenders??
    I just installed the fabspeed headers and I picked up my car yesterday, after 50 miles of driving the car I got a CEL but it doesnt worry me because if you perform a search about the topic is a WELL know issue a CEL could be triggered and the way to fix this is:
    1) regular 02 extenders (this is a hit and miss)
    2) mini cat 02 extenders (this one supposedly resolves the whole thing for good)
    3) tune (this one for sure fixes everything)
    I do not think it is fair to trash the headers when it is (as I said) a well known issue the consequences of installing them.
  3. lethetton
    lethetton Rookie
    Oct 11, 2015
    26
    Houston, TX
    Lee Ethetton
    We knew about the O2 extenders and they were installed. We thought that would resolve the issues. I drove the car for 200 miles and the engine light came on again and brought it to my mechanic. He worked on it for over a week, resetting the computer and testing it repeatedly. I had to move to NC and left the car with him and asked that it not be shipped till this issue was resolved and they tested it over and over. The pattern is odd in that once the computer is reset, it appears the problem is fixed. The next time I use the car, no engine light. The second time I use the car, I have the engine light. I can repeat this condition over and over. It is NOT related to the O2 extenders.
  4. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #4 ferralc, Jun 11, 2016
    It might be related, because as I said the universal 02 extenders are a hit and miss solution.
    Try the mini cat 02 extenders now and see if that fixes the problem, Fabspeed makes them.
    http://www.fabspeed.com/universal-o2-spacers-with-catalytic-converters/
    Some members had the big daddies installed, but do not hold your breath trying to get some support or customer service from those guys, they do not have a number, only an email and they are the worst to deal with.
    Which codes are you getting? P042x and/or P043x???
  5. dm_n_stuff
    Dec 10, 2003
    43,648
    26.806311,-81.755805
    Dave M.
    I am no fan of Fabspeed, but they do have a contact phone #, and I suspect, do answer their phone.
    If this is a known issue, perhaps they have a workaround. Have you spoken with them about this issue?
    888-646-4945
    or
    155 Commerce Drive
    Fort Washington, PA 19034
    P: 1.215.646.4945 | F: 1.215.646.9828
    I have never known them to run from a conversation, even when that conversation isn't always pleasant.
    D
  6. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I was referring to Bigdaddies not Fabspeed.
  7. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    I'm not sure why you say it's not related to 02 sensors. You are resetting the ECU's which resets all the monitors. They run again a few times after you start running the car again. The ECU then detects the cat efficiency to be out of range and sets mode 6 codes that you can't see or set an efficiency CEL.
  8. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    When did I say "it is not related to the 02 sensors"?
    Of course it is related to them, that is the WELL known issue when you replace headers.
    If you read my posts again I told you the 02 extenders are the first step in the troubleshooting process, it didn't work so now you need to go to th second step that is mini cats extenders instead of regular extenders.
    If that doesn't work supposedly the next step is a tune.
    Why don't you call Fabspeed and express your concerns to them?
  9. dm_n_stuff
    Dec 10, 2003
    43,648
    Dave M.
    Couple things.
    1. feralc Chill a little. OP is struggling with a problem, you don't need to get extra defensive. Between his last post and mine, you seem a little, well, edgy and defensive. Maybe a nice Sunday drive will help you relax a bit.
    2. OP>>> This. "Why don't you call Fabspeed and express your concerns to them?" It's their crap you're struggling with, I'm willing to bet you're not the 1st customer to have this issue, and maybe they have a solution.
  10. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    When I had the CEL come on, I called the Ferrari dealership and they recommended the exact same procedure mentioned by Feralc, my next call was to Travis at Fabspeed, their customer service was amazing and YES they have seen this problem before. Travis immediately advised that he will be sending me the mini cat O2 extenders as this should take care of the problem; should that solution fail then they will ask me to sent them the ECU for a tune. Throughout this whole process I found Fabspeed to provide an amazing and prompt service. I am not worried or concerned based on the Fabspeed team's performance so far. I will provide an update once I implement the second step remedy. Happy Sunday driving to all.
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,738
    Lake Villa IL
    If it has a cel it must have a code/codes, what are they?
  12. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #12 ferralc, Jun 12, 2016
    Maybe, I must apologize if I sounded edgy and defensive, i will take your advice and go for a nice Sunday drive.
    I have no affiliation with Fabspeed but I think is unfair to trash one of their products without doing the necessary due diligence about what could happen, Fchat is a great source of information and even mechanics come here from time to time when they can't find a solution.
    After years of coming to this forum I have found that members don't really like when a topic is restarted when it has been discussed dozens or hundreds of times, most of the time those threads don't have replies "a simple search and you will find...." is usually the response.
    I try to respond (if I know) even in those topics to save the OP time and effort, I tried to do the same thing here and I felt like my advice was "questioned"
    Chris: I am sorry I hope you fix your car soon
  13. lethetton
    lethetton Rookie
    Oct 11, 2015
    26
    Houston, TX
    Lee Ethetton
    I appreciate all the input from everyone. The interesting thing is that when we look for error codes, there are not any! That is the most frustrating part of the problem. Trying to troubleshoot the problem without the computer telling us why it is setting the engine error light is the most frustrating part of the issue. We thought we had this resolved in Houston and now I am in Asheville, NC, far from anyone that knows about Ferrari's. I will contact Fabspeed on Monday for input on this issue.
    Frankly, I had seen the comments on these headers before I went to my mechanic to discuss which headers to get and we discussed all these issues and thought we had all that was needed to resolve these issues. He has lost days of non-billable time trying to resolve this problem. I do believe that was doing "due diligence". I was not questioning your advice, as I was trusting my very qualified mechanic, who is now very far away.
  14. RedTaxi
    RedTaxi F1 Rookie
    3,330
    New Zealand
    Glen
    CEL = fault codes. Unusual that your CEL shows no codes.
    I got cat inefficiency codes every time I drove after fitting headers. Extenders fitted and seem to be working for me.
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The issues and resulting problems are very common when the original headers, which had pre-cats in them, are replaced with ones without.
    bellwilliam likes this.
  16. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    Are you checking both ECUs? The first CEL I had showed no codes on the first ECU, I had to switch to the other ECU and I found it, most generic scanners will not see the second ECU, what is your mechanic using?
  17. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    Is this in any way related to the fact that factory 430 headers have precats and most aftermarket units don't?
  18. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    These cars are quirky, it is risky living with these cars in an area where there is no dealer and/or someone with the proper computers and know how to play with them.
  19. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    The easiest way to resolve an O2 error is reprogramming the ecu.
    What tool are you using to get to the error, I've not seen a CEL light and no errors. Something set it off, if ur tools isn't telling you where to look your just chasing you tale.
  20. yangstein
    yangstein Formula Junior
    Mar 23, 2015
    571
    Orange County, CA
    Brian
    OK. I have installed the fabspeed headers recently as well but do not experience CEL issue (Yet / Knock on Wood)
    This is totally different from O2 sensors or extenders that came with the headers.
    My mechanic told me he wouldn't use the gaskets that came with the product where he used the OEM. Maybe that could be the problem?? I don't know but that is what my mechanic did due to his experience with aftermarket headers especially Fabspeed. I have Fabspeed products all over and have never ran into one so far. I even have a Resonator Bypass X Pipe on my Audi S8 and it sounds incredible.. They make good products in my experience.
    It maybe nothing but check with your mechanic what gasket he used.
  21. Steelton Keith
    Steelton Keith F1 Veteran
    7,713
    Raleigh NC
    Keith Hall
    lethetton. Calling Fabspeed is a good suggestion. Foreign Cars Italia is authorized Ferrari dealer with a Charlotte and Greensboro location. The NC Chapter of FCA has several members who live out near you. Why not post in the North Carolina section for local mechanic referrals?
  22. lethetton
    lethetton Rookie
    Oct 11, 2015
    26
    Houston, TX
    Lee Ethetton
    Update for anyone that is interested. My mechanic that installed the headers tried everything with the extenders and I continued to get an engine light, for 1.5 years! He called Fabspeed over and over and got the run around. Finally, about 6 months ago, he reached a knowledgeable person and it turned out there was a new part he could attach to the headers that would fix the issue. I am not sure what the part was, but it cost and additional $130. My only information. After that, no issues. Can pass you the mechanic's name for info if you have a similar issue.
  23. lethetton
    lethetton Rookie
    Oct 11, 2015
    26
    Houston, TX
    Lee Ethetton
    I bought your book and look forward to reading it. Thanks for the suggestions but I finally found a cure to my FabSpeed header issue if you are interested.
  24. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    The additional part are not the mini cat extenders? Because that part fixed my CEL and it has been around for a while now
  25. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
