Fabspeed Motorsport - The BEST 458 Sound? | FerrariChat
Discussion in '458 Italia/488/F8' started by Fabspeed Motorsport, Mar 16, 2021.
Tags:
  1. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    I'm sure we have all seen Normal Guy Supercar and his showcase of 458 Symphonies. We are very proud to receive all the positive feedback that we have. Depending on interest, Would the community want us to hold a group buy on headers or any part of our 458 System?
    https://www.instagram.com/p/CMc-6tasRzA/?utm_source=ig_web_copy_link
    Complete high-performance exhaust solution for the Ferrari 458 Italia; fantastically daily-driveable sound and power from Fabspeed's Valvetronic Exhaust System, Sport Headers, Sport Catalytic Converters, BMC F1 Replacement Air Filter, and XperTune Performance Software.
    The Ferrari 458 Italia Valvetronic Performance Package is the ultimate solution for 458 drivers looking for the perfect balance between a low-rpm, neighborhood-friendly sound, and high rpm V8 roar. We have tested various exhaust, intake, and tune combinations on our in-house dyno, and have found this marriage of parts to be a great answer for increased sound and performance on the 458 Italia. The valve system retains factory functionality, while the improved flow from the exhaust emphasizes the added power, sound, and throttle response provided by the Sport Headers, Sport Catalytic Converters, and BMC F1 filter. We recommend coupling this Performance Package with the optional Fabspeed ECU tune to fully optimize the modifications and extract maximum horsepower and throttle response.
    INCLUDES:
    458 Italia Valvetronic Exhaust System
    458 Italia Sport Headers
    458 Italia Sport Catalytic Converters
    458 Italia BMC F1 Filter
    458 Italia XperTune Performance Software
    FEATURES:
    • Fits all Ferrari 458 Italia Cars (2010-2015)
    • Constructed from high-quality, 14-16 gauge T304 stainless steel C.N.C. mandrel-bent tubing for maximum power and sound
    • Sport Catalytic Converters feature German imported, 200 cell HJS HD catalytic converters which offer 93% of the flow of straight pipes
    • Fabspeed Sport Headers feature a high velocity, 4-into-1 merge collector for improved exhaust scavenging and optimum flow
    • Sport Headers feature 1.875”/44.5mm primary pipes which are larger in diameter than the stock/OEM 1.5” tubes
    • Dual exhaust tones via a vacuum-actuated valve; maintains factory functionality
    • Fabspeed ECU Tune optimizes the air/fuel ratio throughout the RPM range for maximum power to match the increased efficiency from Fabspeed hardware
    • Direct bolt-on application with no cutting or welding required
    • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
  2. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    Check out this new customer video showcasing our performance package!
  3. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    Enjoy the best of both worlds with Fabspeed's Ferrari 458 Valvetronic Exhaust; close the valves for neighborhood-friendly cruising volume or open the valves to unleash the full roar of the Ferrari V8 while adding horsepower and throttle response.
    FEATURES:
    • Fits all Ferrari 458 Italia vehicles (2010-2015)
    • Designed to fit with the factory/OEM Ferrari tips or with any aftermarket tips that are designed to fit like stock
    • Increases power and throttle response
    • Constructed from high quality 14-16ga CNC mandrel-bent T304 stainless steel for maximum performance and durability
    • Direct replacement for the OEM muffler with no cutting or welding required
  4. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    If you did exhaust only and not headers and cats how would the sound be different?
  5. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    2 sets in stock!! - PM me or email [email protected] to claim!
    Removing the factory catalytic converters from your 458 will unleash a lot of sound from the 458's V8. Expect a much more aggressive exhaust note with these Cat Bypass Pipes.
    FEATURES:
    • Fits all Ferrari 458 Italia / Speciale vehicles (2010-2015)
    • Fabspeed's Primary Cat Bypass Pipes replace the restrictive factory catalytic converters with much less restrictive straight-through pipes for maximum flow and performance
    • Direct bolt-on replacement for the heavy factory catalytic converters
    • Adds an aggressive exhaust note for exotic high-performance sound
    • Constructed from mandrel bent T304L stainless steel
    • Simple DIY bolt-on installation, no cutting or welding required
  6. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    How can it be guaranteed for no CEL with the test pipes? I heard the O2 spacer does not work sometimes in preventing a CEL. What other options does Fabspeed recommend to prevent a CEL?
  7. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    Bypass pipes are not 'No CEL garunteed' due to this. We used to be able to tune out engine lights, but due to new EPA regulations, we no longer can! That being said, our O2 spacers do work, just cannot guarantee a specific lifetime due to every car reacting differently.
    That is why they are designed for track use only!
  8. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    The owner of this Ferrari 458 Spyder was looking for more classic Ferrari scream out of his OEM exhaust, so we installed a set of our 458 Sport Cats adding +22 WHP, +21 ft/lbs, and an exotic exhaust tone truly befitting of a Ferrari Engine - all without triggering a CEL! The owner was so thrilled, he's bringing in his Ferrari California next. How do you guys think it sounds?
  9. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    We are proud to announce we have partnered with the pinnacle of automotive detailing suppliers, Griots garage!
    Make sure to use discount code "Fabspeed" on their website for an extra 10% off all products. Truly a match made in heaven!
  10. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
  11. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    With fabspeed exhaust and straight test pipes on the 458 how do you avoid a CEL without an ECU tube? I’ve read the O2 spacers don’t work well for this on the 458.
  12. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
  13. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,136
    Fort Washington, PA
    John S
    These equal length performance headers improve exhaust flow and sports car sound and fit both 458 Italia Coupes and Spiders worldwide.
    SOUND:
    These headers will give your 458 a light increase in volume while the equal length design smooths out exhaust pulses for a smooth high pitched sound and adding significant horsepower while being emissions compliant. .
    POWER:
    Often times headers are the best way to unlock "Clean and Green Performance" emissions legal power on a naturally aspirated engine. On our DynoJet we saw peak curve gains of +41HP crank horsepower (wheels horsepower + 34 whp ) and +38 ft-lbs of torque at 4500 RPM. Theses gains are carried throughout the RPM band with peak horsepower at redline even picked up +16HP. Significant power performance gains while being 100% emissions legal.
    FEATURES:
    • Fits all Ferrari 458 Italia / Speciale vehicles Coupes and Spiders worldwide (2010-2015)
    • Improves power by +41HP crank/ 34 whp and 38 ft-lbs of torque at 4500 RPM
    • Saves 13 lbs versus bulky factory headers that are poorly made and have compromised mass production header tubing.
    • High-velocity 4-into-1 merge collectors for maximum performance alonmg with 321 aircraft grade stainless steel interlocked flexible bellows.
    • Constructed from high-quality 14-16 gauge C.N.C. mandrel-bent T304L stainless steel for optimum flow and maximum durability
    • Simple DIY bolt-on installation- remove factory 458 headers and replace with the Fabspeed performance headers that BOLT-ONTO your OEM stock Ferrari 458 catalytic converters or get the Fabspeed HJS German cats for even more sports car sound and guranteed Clean and Green Power! tm
    NOTE: To ensure proper header seal, after initial heat cycle, tighten all exhaust bolts to the OEM torque specs
