Factory Becker CD Player BT Adapter with Controls? | FerrariChat
Discussion in 'Technical Q&A' started by @CTEVN, Feb 13, 2020.
  1. @CTEVN
    @CTEVN Karting
    63
    I have found lots of companies selling the Bluetooth adapter that plugs into the back of the becker factory unit, but 99% of them all say it won't let you control via the front, control the play, pause, skip songs part via the BT connection.
    I did see that another companies offering up becker BT controllers say it would in their cars let the BT control via the decks factory buttons, but no idea if it would work for a 360 becker deck, anyone here have direct insight?
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,667
    Just East of Weird
    Bob
    Send a link to the second one you mentioned. I haven’t seen any BT controllers that allow you to use the factory radio buttons. It’s all been on the device.
    Or folks swap out the Becker radio for an aftermarket one to have full features. You could always call Becker auto sound and ask them.
    Sent from my iPad using Tapatalk Pro
  3. @CTEVN
    @CTEVN Karting
    63
  4. @CTEVN
    @CTEVN Karting
    63
    Plug looks the same, and says supports Traffic Pro
  5. 24000rpm
    24000rpm F1 Rookie
    have you tried it and the OEM knob would control the bluetooth music on your phone?
  6. @CTEVN
    @CTEVN Karting
    63
    No haven’t tried it yet, as hoped someone else has tried. Amazon doesn’t have stock so don’t feel like being the tester on this. I have the BT version that doesn’t support control, but it be nice to have the controls working so oassanger can adjust.
  7. 24000rpm
    24000rpm F1 Rookie
    the thing you posted, it has the wrong connector. It should be a blue one
  8. f355spider
    f355spider F1 World Champ
    17,934
    I went with a corded connection to my iPhone for the Becker 6112 in my 430 Scuderia. This outfit has a number of options both BT and corded, you might give them a call and speak with them
    https://www.discountcarstereo.com/
  9. @CTEVN
    @CTEVN Karting
    63
    @24000rpm I bought and installed the YATOUR works 100% also 100% works to control my phone via the becker unit, so that was a real BONUS!
    Haven't tried to answer calls yet from the becker headunit, but should work. So far skipping tracks, pause/play all works for the headunit, almost
    like factory...
    24000rpm and f355spider like this.
  10. 24000rpm
    24000rpm F1 Rookie
    Is this exactly what you installed? Is there any difference on the connectors?
    i wonder where the power for this thing come from
  11. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    They schematics of their units on Amazon show a USB cable supplying power.
  12. 24000rpm
    24000rpm F1 Rookie
    I think that's an usb port on the device that provides power to other things, such as cell phone
    killer58 likes this.
  13. @CTEVN
    @CTEVN Karting
    63
    Here is the item you need to buy, plus amazon now has it under prime, so that is why I took the chance to buy it, but not to worry 100% works, have the right power connection and everything is great, am so happy to be able to control from my headset:
    https://www.amazon.com/gp/product/B07D9JW6S1/
  14. @CTEVN
    @CTEVN Karting
    63
    also as a surprise bonus on this thing, the USB output now I use to power up my GPS unit/backup camera. So it really perfect, as didn't have to do any fancy wiring to get a switched USB power line added to the car. I use the garmin GPS with the wireless backup camera, so added so much to the car.
    f355spider likes this.
  15. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Previously Maranello
    thanks for your help guys, I am following the same path for my Beck radio on a 456GTM. I will let you know the result.
  16. @CTEVN
    @CTEVN Karting
    63
  17. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Excellent tutorial. Thanks for the tips on additional remote or mike
  18. 24000rpm
    24000rpm F1 Rookie
    #18 24000rpm, Jul 8, 2020
    so, just bought it and tested.
    on my 360's becker BE6104, it works
    on my 430's becker BE6112, it DOES NOT WORK. no sound at all
  19. 24000rpm
    24000rpm F1 Rookie
  20. 24000rpm
    24000rpm F1 Rookie
    update:
    i tangled with my 430 and 360's radio harness and switched head units,, etc etc, for 3 hours.
    it looks like my 430's head unit is bad.
    it should work on the 430 too!!
  21. f355spider
    17,934
    I tried the Yatour on my Becker 6112 in my 430 Scuderia and could not get it to work properly. I returned it to Amazon. My lightning cord connection still works fine to my Iphone instead. Which doubles for charging as well.
  22. @CTEVN
    @CTEVN Karting
    63
    Yah I actually using/updated to a 430 stereo in my 360, works the same. I updated to the 430 as my 360 was a tape player and didn't have the subwoofer output, 430 did :) and was CD...
  23. 24000rpm
    24000rpm F1 Rookie
    #23 24000rpm, Jul 8, 2020
    The yatour is made in China. I fortunately contacted the factory when I was buying one a few days ago. The factory is not sure if it works on be6112, but told me it works on be6104. The company also told me a few models of yatours exist, with various connections, including blue only connector and blue+green connectors.
    So I think there's a lot of confusion here.
    For those claiming it to work / not work
    please tell us the following:
    1. Does it work for you?
    2. how many connectors your yatour has , just a blue one or a blue one and green one connected together? (see post below)
    3. what model is your head unit that you plug the yatour into?
    4. what is your car? 360 or 430?
    5. does your car has a cd changer, originally?
    6. what body type is your yatour ( see post below)
  24. 24000rpm
    24000rpm F1 Rookie
