430 - Factory gated vs conversion | Page 2 | FerrariChat
430 Factory gated vs conversion
Discussion in '360/430' started by efg2014, Jan 5, 2024.
  1. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,476
  2. Mario Andretti
    Mario Andretti Formula 3
    1,774
    Boston
    How do you check for over revs ? the only ones that I know of is some flavors of 911's and the Nissan GTR....
  3. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    You should be able to do that with a Lenoardo or something equalivant that reports the revs per gear recorded. I am not 100% on this but I sure hope so!
  4. swc5150
    swc5150 Formula Junior
    721
    Wisconsin
    Scott Calderwood
    #29 swc5150, Jan 9, 2024
    I would think it's the same on a 360, but you can't over-rev a 430 F1. The computer will only select a gear within the rpm range, or simply not comply with your request (if you accidentally double tap the paddle at high speed for example).
    cavlino and collegeboy like this.
  5. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    That was my understanding also but I didn't want to test it
    On the Stradale though if you put it in Race mode all bets are off, so be Careful!
  6. swc5150
    721
    Wisconsin
    Scott Calderwood
    The 430 has Race and then the "all nannies off" switch, but even then it won't let you over-rev fortunately. Track test not by me, but a club buddy:)
    cavlino likes this.
  7. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    That is very reassuring to know!
  8. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
    The F430 is four valves
    cavlino likes this.
  9. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
    I have a factory SDX system you can check this on the 430
    cavlino likes this.
  10. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Good point, I forgot I was in a thread specific to the F430.
  11. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    Maybe that was possible on the 355? If my understanding is correct, it was a bit more primitive system with no rev-matching. I find it hard to believe that the 360/430 F1 would allow for such an easy-to-make mistake given there's no advantage to allowing it to happen, and there are so many other safeguards built into the system.
    cavlino likes this.
  12. modificator
    modificator Formula Junior
    434
    Florida
    George
    I think the previous poster made the opposite point. That buying F1 and converting to manual ensures that F1 system did not allow the car to be over rev. But any manual car (factory or conversion) cold be over rev.
    But I think only cars which have been raced would ever be over reved. I don't see a reason for doing it during normal driving. When I was racing in my younger days I would regularly over rev engine in a Honda Civic - not loosing time due to gear changing could be huge on a race track (and used Civic engines are cheap to buy and cheap to swap). I would never do it in a Ferrari and I don't think that many people do. Unless they miss a shift, which again should not happen in normal driving.
    cavlino likes this.
