Faint clicking steering wheel | FerrariChat
Discussion in 'FF/Lusso' started by haithman, Jul 1, 2022.
  1. haithman
    haithman Formula Junior
    Aug 12, 2004
    272
    Fairly new to Ferrari but wanted to see if what I’m experiencing is normal or not. I’ve noticed that when I turn my steering wheel to make a turn or when getting out of a parking spot there is a faint clicking sound coming from the steering column.
    Sounds almost like the sound you would hear in a combination lock or from turning the bezel of a rolex submariner. Is this normal? It doesn’t sound “broken” but I wouldn’t have expected to hear a mechanical noise from turning the wheel.
  2. Gh21631
    Gh21631 F1 Veteran
    9,189
    East
    Not normal, go see your dealer.
  3. R J
    R J Formula Junior
    May 17, 2017
    602
    Are you sure steering column? Or actually from the steering wheel? Had this on my Aston (not Ferrari). It was the airbag in the steering wheel - something had come loose inside. Needed airbag replacement.
  4. haithman
    Aug 12, 2004
    272
    #4 haithman, Jul 12, 2022
    Hopefully this works but attaching a link to a video with the sound.
    Car will be picked up this weekend to be looked at.
    Qavion likes this.
  5. Dubaicity
    Dubaicity Karting
    Nov 21, 2013
    244
    Germany
    That is definitely not normal!
    Gesendet von iPad mit FerrariChat
    350MH83 likes this.
  6. haithman
    Aug 12, 2004
    272
    Yeah I figured. Sent the video to the dealer and they are picking up the car this weekend. Service advisor thought it could maybe be the clock spring behind the steering wheel but I have no faults and all buttons work on the wheel. Will update once they take a look this weekend.
  7. sunghyun7
    sunghyun7 Formula Junior
    Oct 7, 2019
    256
    did the car have steer-wheel out service recently? sounds like broken clock spring. or could be just 2 materials rubbing against each other. does everything work on the steering wheel? btw, sounds like bezel on rolex? lol. I personally have no idea what that sounds like. but that sounds like loose clock spring wire potentially! should be easy fix if it is that.
  8. haithman
    Aug 12, 2004
    272
    Yes everything works. Service advisor’s first guess was clock spring as well so we will see.
    sunghyun7 likes this.
  9. haithman
    Aug 12, 2004
    272
    Ended up being the clock spring
