Fake?? | FerrariChat
Fake??
Discussion in 'Aviation Chat' started by msdesignltd, Jun 12, 2015.
  1. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,296
    NYC. / E. Hampton
    Michael
  2. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    I think it's genuine. Paris air show is on this week and I have seen reference to their flight demo in some French websites too.
    I also think the angle of camera is deceiving a bit. That's a very steep climb but not vertical. Still the bird does fly very well.
  3. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    That take off is not a photoshop special. The airplane is very light and has a lot of horse pressure. Plus they have some very good pilots on the program and they know the limits of the airplane. Boeing would never publish something phony about their airplanes.
  4. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
  5. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,162
    Adelaide, South Aust
    Steve
    It's real, but might as well be fake.
    Have they lifted the FL290 icing restriction yet?
  6. zygomatic
    zygomatic F1 Veteran
    5,063
    Washington, DC
    Chris
  7. msdesignltd
    20,296
    NYC. / E. Hampton
    Michael
  8. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,308
    In the beginning of the video the Typhoon scared the s#!t out of me!
  9. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    #9 LouB747, Jun 12, 2015
    While impressive, I'm guessing it's no where near vertical. Those angles always look weird to me. Here's a shot of a JAL 747 departing LAX. While it looks extreme, it's probably no more than 20 degrees in this shot.
  10. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    On the 747-8, with essentially the same engines, the restrictions have been lifted to 35,500 with some limitations. Basically if you are at a light weight, you have to fly faster to keep the N1 and N2 up. There's a chart with Altitude and weight vs speed. I'll see if I can post it.
  11. Steve355F1
    Aug 26, 2011
    17,162
    Steve
    That's a wonderful pic
  12. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    low fuel, no passengers, no baggage/freight I would imagine it is quite the performer in that condition
  13. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    That is what I said in an earlier post. Light weight and lots of power and a good pilot.
  14. Ak Jim
    Ak Jim F1 Veteran
    9,621
    North Pole AK
    Wouldn't most empty transport category perform like this or does the 787 have a higher thrust to weight ratio?
  15. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    a performance take off is impressive to see, but essentially not a big deal...
    it's about having enough momentum for a few seconds to have an aggressive angle attack and gain some altitude, which creates the wow factor... there are military aircraft ( without payload ) that have do not need to depend on illusion to do an aggressive climb out...
  16. jcurry
    24,082
    In the past
    Jim
    You can see in the video where they keep the NG down longer than would normally be required to gain extra speed at min drag, then followed by an aggressive pitch up. Just your typical obstacle take-off technique.
  17. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Oh, come on!
    Now this dude, on the other hand, had a right to be scared. And to have his replacement knickers paid for by the network...
    https://m.youtube.com/watch?v=4iOoiEbtf2w
  18. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    As Bob Hoover aptly demonstrated in numerous airshow routines, you can do a lot of things so long as you don't lose ALL the airspeed. They gain some speed by keeping the nose down at full power and then go near vertical and as it bleeds off push it back down.
    It's not that it's a big deal, but the impressive thing here is that the 78 has the power that a light weights can keep it vertical for as long as they can.
    Since this is essentially a low speed maneuver, bigger bypass engines really help a lot. Older turbojets and smaller bypass fans can do it, but with the new generation of big bypass engines you get a lot more thrust at lower speeds, and that is what makes this more impressive.
    Think about it another way. The empty thrust to weight ratio of a 787 is about .5 lbs of thrust per pound of aircraft.... The empty thrust to weight ratio of an F-86 is about .53... Only 6% better..
  19. s52
    s52 Karting
    Oct 14, 2014
    168
    East Bay
    Christian
  20. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    It actually takes a tonne of power to get vertical right after takeoff WITHOUT accelerating at low altitude to build up energy in the form of speed to later trade off for whatever thrills are in store. To climb at whatever speed the gear comes up at plus whatever is added while pitching up to vertical while maintaining that speed, or gaining more speed, necessitates a thrust to weight ratio of 1:1 or better.
    I couldn't find the outside view video of this maneuver that the birds used to do...but for pilots, it really is one of their coolest tricks. Taking off, sucking up the gear and proceeding directly into a loop is every bit as cool as ripping down the runway and crossing the departure end at 500 knots then climbing to the moon.
    https://m.youtube.com/watch?v=N2gP0VryXZQ
  21. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    #21 El Wayne, Jun 13, 2015
  22. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    Here you go:
    [ame]http://www.youtube.com/watch?v=SNplaq8uwUQ[/ame]
    [ame]http://www.youtube.com/watch?v=PyjNsxLp4rk[/ame]
  23. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,750
    Oregon
    Gabe V.
    If anyone in the aviation arena has seen with their own eyes the performance of B-52 bomber combat maneuvers as a comparison for "heavies" performance envelope, knows this demonstration is completely legit.
  24. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,308
    Holy Mother of God!! The Jumbo looks E P I C.
  25. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,782
    IgnoranteWest
    What's the camera platform on these shots, and what are its altitude/position relative to the runway and the subject aircraft?
