Fan belt squeak on high revs gear change 458 Spider | FerrariChat
Discussion in '458 Italia/488/F8' started by gagoha, Oct 19, 2017.
  1. gagoha
    gagoha Rookie
    Sep 9, 2014
    29
    I love the sound of the 458 but I feel it is slightly ruined by a belt squeak at high revs gear change. I initially thought I needed a belt change but listening to youtubers, I hear the same on their cars. It doesn't seem to be a problem on the 488's though. Any idea of a fix?
  2. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    835
    Michigan
    Tony
    I get it when it is colder outside (50 degrees) and when I shift at higher rpm. At temperatures above 60 degrees, I don't have an issue. I spoke to my mechanic and he said it is common on the 458. He mentioned it wasn't anything to be concerned about. my .02
  3. rlips
    rlips Formula Junior
    Jul 29, 2011
    959
    New Jersey, USA
    I had it on my 458. Belt changed helps, but it eventually comes back.
  4. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    This is an annoying part of the 458. Once you hear it, you always listen for it!!
    May the Horse be with you....
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    They all do it. It is just part of the charm of the car. Ferrari has never come out with a fix for it.
    AlfistaPortoghese likes this.
  6. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,648
    An overrunning alternator pulley may do the trick?
  7. Illogical
    Illogical Rookie
    Oct 17, 2017
    28
    There are aerosol belt dressings available that may help, although they may need reapplying occasionally.
  8. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    I must say I'm a bit puzzled when every now and then such a topic arises.
    I sometimes hear it when I'm watching the video I made on my phone or on my laptop.
    Driving the car I can't hear it 90% of the time and 100% of the time I don't care.
    Ferrari never came with a fix for it... Because imho, there's nothing to fix.
    For me, it's like complaining that in the 488 you sometimes hear the turbo spooling up on some circumstances and say Ferrari needs to fix this because it ruins the driving experience.
    Kind regards,
    Nuno.
    338Lapua likes this.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Where are you going to spray the belt dressing? You cannot even see any part of the belt unless you are under the car with the undertray off.
  10. Solid State
    Solid State F1 World Champ
    10,580
    Maximus Decimus Meridius
    Because they are two different engines I would assume. One is a 9K NA screamer and the other is a smaller 7K turbo more similar to the California architecture.
    Afonsolaw likes this.
  11. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    never had it ... so: NOT ALL .... :D
