fan help... | FerrariChat
fan help...
Discussion in '365 GT4 2+2/400/412' started by koisokok, Sep 20, 2007.
  1. koisokok
    koisokok F1 World Champ
    12,302
    nine 0 two one 0
    #1 koisokok, Sep 20, 2007
    how do i get the yellow fan to work?? would love to keep the engine cooler in bumper to bumper traffic in los angeles..is it possible??? i attached a photo,,,
  2. KraigG
    KraigG Formula 3
    May 25, 2006
    1,501
    Willow Springs
    Kraig
    Mine turns on automatically when the engine reaches a certain temperature. How is your fuse?
  3. 400 gts
    400 gts Karting
    Apr 4, 2007
    58
    West Palm Beach, FL
    B.I.
    You can bypass the thermostat unit, and have the fan motor hard wired and starts when you turn on the ignition. I did it for the same reason. Also check to see if the fan blade spins easily. Mine did not, and I had to take out the little screw in front of the fan motor, spray WD 40 on the end of the rotating shaft, and the put the screw back, works great.
    400 gts.
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Two front fans turn on when the the aqua temps are straight up @ 12:00 on the guage, the yellow fan is for the a/c for further cooling during that operation, & I think it turns on right away when the compressor kicks in.
  5. koisokok
    12,302
    nine 0 two one 0
    thxs, i was wondering when that thing would kick in...both my front fans would start up but i let the car run for a while and the yellow one never did..maybe it wasnt hot enough..
  6. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    If I'm not mistaken, its dedicated to A/C operation (if memory serves me correct/couple of years ago).
    Nice motor! Whats your miles?
  7. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    The yellow fan on the engine side is operated by a thermo switch screwed into the bottom of the radiater, if you touch the two leads togeather ( it is a grouding switch, hard to find ground though) and the fan works with ignition on, switch is inop. about $49.00. There are also realays under the pass. foot board. Same part # on the head light relays so you can do a switch to check the fan one.
    The two fans in front of the rad. come on as soon as you switch on the a/c. Those fans are made in England and were used on the J. XKE. I found them cheaper through GT cars for Ferrari than Moss motors for a british car. Good luck
  8. koisokok
    12,302
    nine 0 two one 0
    thxs, have about 9400
  9. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I have never seen anything above 90C water temp. in my car in all kinds of driving, including the weekend traffic jam around Wash. DC. At 80+ mph the oil gets to about 105C but it is much cooler in traffic. I use a coolant additive but I am sure that is not miracle fix just a couple of degrees of insurance.
    I was surprised to hear some people running hot with their 400's.
    Ken
  10. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    NAPA has the Veglia switch available in several temps..I personally use the 160 degree one just because I don't trust ANY switch to come on until it's past its stated temp...also it now comes with its own dedicated female GM type connector already attached$16-20) with the matching male connector available ($3-$4) that can be used by clamping on to spade connectors to match the car's existing leads..What an improvement..I have found that if the change over to the new switch is done when the coolant is cold and the new threads are wrapped with tephlon tape..this whole operation takes about 3-5 minutes and loosing about a cup to a pint of coolant and with no need to "burp" (blead) the system because you have'nt let any air into the system..love those GM connectors..because this is the perfect time and place to add a manual overide switch..Jacques
  11. rickard
    rickard Rookie
    Apr 13, 2007
    38
    toronto canada
    rick impera
    Double check the fuse. Sometimes even if it looks good, the contact is not made. So give the fuse a little spin.
    Rick
    Nice clean engine.
