fan help.. | FerrariChat
fan help..
Discussion in '365 GT4 2+2/400/412' started by koisokok, Oct 5, 2009.
  1. koisokok
    koisokok F1 World Champ
    12,301
    nine 0 two one 0
    #1 koisokok, Oct 5, 2009
    can someone please tell me if both fans should come on when the car is hot? seems that the yellow visible one (left corner of pic) does not come on. i hear the other one come on but this stays still..thxs, kerim
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Kirem, I believe the yellow fan kicks in the same time as the 2 fans in front of the rad. do.
    Bruce
  3. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Are your fuel injection lines between the fuel distributor & the WUR (warm up reg./between the power steer'g. res. & the 'Ferrari' valve cover) coming in contact w/valve cover? I spun my tie wrap so that the base of the tie wrap was standing the lines off the cover, I don't think heat, abrasion, & fuel are a good mix.
  4. koisokok
    12,301
    nine 0 two one 0
    no ,they have good clearance,,looks like it though with the angle of the picture..thxs bruce..
  5. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Mandeville, Louisian
    Dave Foley
    #5 Godspeed!, Oct 5, 2009
    As designed, the yellow fan comes on based on the thermo switch at the bottom of the radiator. This switch closes around 180 or so. The fan on the pass side in front of the radiator / condensor is to come on when the a/c is turned on.
    Not sure on this part, but some cars are set up so that even with the a/c off, if the temp gets to a predetermined point, the second fan will come on.
    Very clean eng compt by the way................
    Godspeed!
    Dave
  6. koisokok
    12,301
    nine 0 two one 0
    thxs dave, so my temps were getting up there and the yellow fan did not kick on, maybe a relay? thanks for the input..
  7. alastairhouston
    alastairhouston Formula Junior
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
    Had similar problem with my older 400gt one fan not working found to be bushes worn out on fan motor.
    have a check easy to get at. I tried to make up new bushes from an old vacum cleaner alas just couldnt get it right and ended up getting a second hand replacement fan.
    I am not sure but both fans come on when the temp rises and are surely needed.
    Good luck
    Regards
    Alastair
  8. koisokok
    12,301
    nine 0 two one 0
    ok so at idle both front fans came on. first the passnger side came on around 95, then the driver side kicked on about 100 but then it creeped up to almost 108 and the inside yellow fan never came on..so i take it i have a problem with that fan.
  9. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    On my 84 and 82 both. All 3 fans come on simultaniously or so close that you cant tell at about 95 deg C. The single fan in board of the radiator will also come on independant of temperature any time the A/C compressor is activated.
