FARTING 308 STYLE | FerrariChat
FARTING 308 STYLE
Discussion in '308/328' started by gilligan308, Feb 4, 2012.
  1. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    OK F chatters, It seems that lately when I start the 81 gtsi up cold it will buck like someone advanced the ignition on it like a normal distributor. Since this is all electronic with non adjustable distributors what has moved? Also it will start up run smooth and powerful then with out notice start popping out the exhaust and start bucking like it had an old cracked distributor cap. Both caps and rotors were replaced last year and now the wires this year and yes all wires are where they are supposed to be.It is weird. Maybe digiplexers? My background is well versed with diesel and gasoline rebuilds, injection ,etc., But what the hey I guess I don't speak Italian good enough!! Any Ideas?
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    It looks like you have an US spec gtsi like mine. There are several quick tests I would run. First I would pull the extenders and inspect them for buns and ensure they were attached to the plugs properly. While the extenders are out, blow out the spark well with compressed air. Alot of times water can get into a well and create a path to ground that can act random. Next check the timing at idle. At idle with vacuum the timing should be 3 deg atdc (this is the latest ignition timing I have ever seen on a car). With the vacuum line disconnected timing should avance to 6 deg btdc. Check both banks. Next is start pulling plugs and looking at them. If that doesn't help PM me. I will be with 2NA tomorrow and we should be able to figure it out.
  3. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Check your warm-up regulator operation and control fuel pressure.
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    FWIW - check the rotors again - I replaced mine and about a year later on one of the screws on the top of the rotor backed out and cracked the rotor but not the cap - just saying.....
  5. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    I was just looking at the shop manual and it says in figure D3 that the firing order is 13574826 which is not what i knew it to be. Which is correct any one? I went out tonight to the corral and fired her up and it ran perfectly. Then after 3or4 minutes I revved it up then back to FART pop chug. HMMMMMM! Seems like the timing trigger is all over. where is the sensor? Maybe ?
  6. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    If you have what appears to be ignition problems, even thought you have fresh rotors, caps, wires, extenders and plugs, and the problem is still there, it could be RPM sensors, TDC sensors, or the Digiplex units themselves.
    I found that my 308 ran crappy for 2 reasons, 1) the RPM sensor was going bad (no output) and 2) one of the 2 Digiplexes was bad, no more advance, not sure if it was a pneumatic problem, a mechanical problem, or an electronic problem.
    Since I can't find anyone out there who even claims to know how to diagnose and fix a Digiplex ( I contacted many vendors) I got a distributor-less ignition system out of a Mustang and put that it.
    There are a number of legitimate Ferrari-grade aftermarket replacement ignition systems that can replace the tuckered out digiplexes.
    If there is anyone out there who can point to a competent digiplex rebuilder, I'd be impressed. I could not find anyone.
  7. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    Andy how did you get the mustang ignition to fire two coils?I tested the vacuum and pumped it up and timing seems to change so I hooked it back up .i then found a vacuum hose off at the cold idle but that didnt change things just picked up the RPM as usual. I will look at the other parts before I give up on the Digi's
  8. andy2175m4@yahoo.com
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    the ignition system has 4 coils, does not use the Ferrari coils. It's a wasted spark system, when it fires the firing cylinder, it also fires the complementary cylinder at the top of the exhaust stroke at the same time. The spark plug firing at the top of the exhaust stroke does nothing. In theory the plugs may wear faster, but my Mercury with the same ignition system has 80,000 miles and I have never changed the plugs so it really does not matter.
  9. andy2175m4@yahoo.com
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    #9 [email protected], Feb 4, 2012
    I don't know what shop manual you are using, but the 1982 Mondial shop manual has the WRONG firing order. How the Hell did that happen ? I hope they fired that guy.
    I went to google images and searched on Ferrari V8 firing order engine plates and found some photos of old Dino engines that had firing order plates on them. For some reason the 308 does not have this plate, but it's very useful.
    BTW I have never found a 308 GTSi shop manual so I use the Mondial Manual on line.
    I took a huge magic marker and wrote the (correct) 308 firing order on the shop light over my bench. I pulled my hair out for a long time over that incorrect firing order in the Mondial manual.
  10. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    YUP thats what I used was the Mondial manual and thoughtI had it wrong but it runs to good normally. I will try replacing the trigger sensor and RPM sensor. Just plain old odd. Thanks!
  11. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    That's fantastic :)
