fast idle device reinstatement | FerrariChat
Discussion in '308/328' started by alan p. read, Sep 28, 2016.
  1. alan p. read
    alan p. read Rookie
    Jun 26, 2006
    15
    essex. england
    alan p. read
    hello everyone, a bit of a funny one this one. a few years ago i removed and serviced the weber 40 dcnf's. as i remember, the fast idle device made it difficult to access a few of the carb bolts, so i removed it.and i left it off. i am now refitting it.now here's the funny bit... i'm sure i remember some liquid in the cavity that the bi-metalic coil spring sits on. i didn't give it much thought at the time, but now i'm thinking, as the spring relies on water temp to react, a liquid of some sort makes a bit of sense as it would connect better to the the cooling system. is my memory playing tricks on me?
    any inputs gratefully received.
    alan.
  2. Steve Magnusson
    26,806
    It's dry - being directly bolted to hot water crossover pipe (and the good heat conduction of the metal) everything heats up pretty well matching the coolant temp. You wouldn't want it wet -- it would just corrode and probably leak ;)
  3. alan p. read
    alan p. read Rookie
    Jun 26, 2006
    15
    essex. england
    alan p. read
    thanks steve, i'll go with that.
  4. alan p. read
    alan p. read Rookie
    Jun 26, 2006
    15
    essex. england
    alan p. read
    all done. works good. also an added bonus was balancing front and back carbs was easy. all good.
