Faulty switch ??? | FerrariChat
Faulty switch ???
Discussion in '456/550/575' started by Boy Wonder, Jan 25, 2021.
  1. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    the switch that activates the cap cap on my new ( to me) 575M is or seems to be in-op lll
    it is possible that the solenoid is NG , but i need to know how to remove the switch without marring the finish of the place it's inserted into
    can i just pry it out with a sharp tool?
  2. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,271
    Northern Virginia
    Cap cap?
  3. tazandjan
    39,170
    Fred- Try one of the plastic/nylon tools used for interior work. Usually available in sets very cheap.
    Those two switches (fuel and trunk) are identical except for markings, so pull both and swap them to see if it is the switch.
    Qavion likes this.
  4. vandevanterSH
    vandevanterSH F1 Rookie
    3,188
    AR
    Stephen Van Devanter
    Do you hear the solenoid working? If so, I had the same problem, with solenoid making "noise" but filler cap not opening. I think i opened the hatch with a plastic card. Bending the metal catch slightly solved the problem. (FWIW, IIRC, this was an Oh!!! Sh*t moment...I was running on empty and in the middle of nowhere, at night, and the gas hatch wouldn't open)
    Qavion likes this.
  5. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
  6. tazandjan
    39,170
    The rubber paint protector in the fuel filler well will also sometimes foul the release if not carefully folded and inserted.
    Qavion likes this.
  7. Qavion
    14,290
    Ian Riddell
    Seems to be a common theme on Ferraris. Same on my F355. Sometimes you can get extra purchase on the release mechanism with the backup
    Fennicus likes this.
  8. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,271
    Northern Virginia
    Oh, gas cap. Sorry, I couldn’t make that out. Lol.
    what was said above is good advice.
  9. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    yes, GAS Cap
  10. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    yes, GAS Cap
  11. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
  12. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    initially , neither of the switches worked, but last night , the trunk latch activated, and was able to pull the release cable,,
    i manually flexed the solenoid latch , but that doesn't do it either,
    the car came from Florida , and i am in Colorado with freezing temps, perhaps the cold might have something to do with it
    i assume the switches can be pried out and they are held in by little snaps on 2 sides, but i would like confirmation before i try that one
  13. Qavion
    14,290
    Ian Riddell
    Both not working? Do you need the ignition on to operate these switches on the 575?
    It's still not clear if you are hearing the solenoid activate (see post #4). Usually you can hear something trying to open the lid. If you can't hear anything, then it could be the button, it could be the fuse or it could be the solenoid. There is also a relay associated with the fuel lid (R12).
    Before you risk breaking the switches, I would try checking fuses, swapping relays, etc.
  14. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    Try this thread. Start with post 2, should help.
    Bill
    FL
    https://www.ferrarichat.com/forum/threads/more-sticky-repair-re-door-card-door-panel.527087/#post-145341651
    Qavion likes this.
  15. tazandjan
    39,170
    Ian- No, both those switches work with the ignition off. At least they have for 13 years for me.
    Qavion likes this.
  16. Qavion
    14,290
    Ian Riddell
    Weird. The owner's handbook says relay R12 is:
    "Attuartore cofano e sportello benzina
    Lid and fuel tank flap actuator"
    Attuartore cofano = bonnet (hood) according to Google Translate. Why would you need a relay (for power) if power comes straight off the battery? If there is a relay between the buttons and the actuators, then you would need two relays.
    We really need some wiring diagrams for these cars.
  17. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
  18. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    the trunk latch works,, so it s not the fuse,, i think its the switch
  19. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
    What he said. Cheers!
