FChat Completed Models and WIP Thread | Page 37 | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by zoRob, May 22, 2009.
  1. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,420
    michigan
    john
  2. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,420
    michigan
    john
  3. F1tommy
    F1tommy F1 World Champ
    11,693
    Sugar Grove USA
    Tom Tanner
    Very nice!!
    John, I don't know if you remember but one of the best model builders I have seen brought models to the Ferrari Literature show at Continental. He was from Detroit, although he has now moved to Puebla Mexico. He is an engineer for VW. I loved his white Ferrari 550 M with opening doors. Alot of passion in their work, thru car lovers.
    Normally I would say military modelers are the best, but some of the stuff the car guys can do will blow your mind.
    Lusso123 and jm2 like this.
  4. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,420
    michigan
    john
    Yes I do remember. Great talent.
  5. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,420
    michigan
    john
    Yes, I believe so.
  6. bigodino
    bigodino F1 World Champ
    13,221
    The Netherlands
    Peter den Biggelaar
    Finally some progress on my 308 GTB/M build! Getting some colour on the model. A lot of masking to get the white stripes done. Still quite some touch ups needed because of paint bleed. This is my second paint job on a whole 1:18 body, learning all the time. The decal sheet does have the stripes, but most decals on this sheet are too large for the model. I also ran into some inaccuracies on the model itself, mainly the engine hood. I'll have to make some compromises. for example I won't be able to apply the Pozzi decal on the engine hood, but that's okay.
  7. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    More progress! Paint is done. Now it's time to reassemble everything. Next up is fitting the scratch built dashboard. Hope it will slide right in! After that some more details like the lightpod, mirrors, exhausts and roof antenna. Final part of this project will be adding the decals.
  8. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    The GTB to GTB/M conversion is finally done! It started way back in 2005. The only 1/18 scale 308 at the time was made by Kyosho so I started out with that. I quickly learned that Kyosho models are a pain to disassemble and reassemble and I put it a bit on the back burner. I also didn´t have much space at the time to work on models. On top of that Ottomobile came out with their version of a GTB/M so I left it at that.
    But in 2012 I bought a 308 by Hot Wheels, which was a much easier base to work on. A lot has been done to make it into a GTB/M: rear fender flares, Stratos wheel conversion, completely different interior, shortened rear bumper and license plate recess delete, new front lid accommodating one instead of two wipers, lower front spoiler, Stratos exhaust pipes etc.
    The project nearly went south today with the finish line in sight! The quality of the decals is mediocre to say the least and some started to fold on the model. I applied Microscale Micro Set but it didn't seem to work. I abandoned the project to search on Ebay if there were better decals available, but unfortunately not. The seller I got the decal sheet from has a bit of negative feedback about the quality. Also the size of many of the smaller decals is too large. So I had to leave them out. No big deal, I wasn´t going for a historically correct livery of some certain rally anyway.
    When I got back to the model, to my big surprise the decal had set all by itself! So I was back in business and able to finish off the build.
    It now sits in my display cabinet along a regular 308 GTB, in line with my display theme of 'street versus competition'.
    LVP488, Aardy, rei24 and 8 others like this.
  9. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    I'm currently working on another project and have de-chromed a few small plastic pieces by using Mr Muscle oven cleaner. This works amazing. In fact it works so well, the paint is completely gone. Not even any residue in the container in which I put the pieces and oven cleaner. So where does the paint go?? I'm puzzled...
    jsa330 likes this.
  10. jsa330
    jsa330 F1 World Champ
    10,059
    75225
    Scott
    I need to try that - been using brake fluid to strip chrome parts. works fine but really messy.
  11. F1tommy
    11,693
    Sugar Grove USA
    Tom Tanner
    Yes, Dot 4 is the best :) I think the future is diecast conversions. The plastic kit industry is almost dead other than for military. I do prefer 1/24th and 1/12the over 1/18th.
  12. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    What do you guys use for sculpting wide fenders or fill bigger holes? I've tried Tamiya putty but that doesn´t work well. Difficult to apply in larger shapes (it wants to stick to the plastic applicator that I use) and when it hardens it caves in. I thought about using air dry clay?
  13. Martin308GTB
    Martin308GTB F1 Rookie
    4,326
    Black Forest Germany
    Martin N.
    Depends on the substrate. What do you have? metal? polysterene plastic? Resin?
    Best
    Martin
  14. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    Mainly resin, sometimes metal.
  15. Martin308GTB
    4,326
    Martin N.
    You can try two-part filler. For bigger holes even glass reinforced. BTW, those pro materials used in the 1:1 car craftmanship are much cheaper -quantity related- than any modelling stuff.
    For not so big holes and smaller imperfections I always used a two-part acrylic glue like Pattex Stabilit (as far as I know available in NL). It's a bit of work to sand it, but it won't cave in. Not even after months, what's sometimes a big annoyance, when it happens after an otherwise perfect paint job.
    bigodino likes this.
  16. bigodino
    13,221
    The Netherlands
    Peter den Biggelaar
    Now that you mention it: I've used 1:1 car filler in the past and it worked really well. Thanks for reminding me! This is what I used:
    Lusso123 likes this.
  17. Martin308GTB
    4,326
    Martin N.
    Sounds good. Though I have no experience with 1-componente Polyester filler regarding caving in. But if you say, that it worked well, one saves the hassle of mixing filler with hardener.
    Best
    Martin
  18. rysc97
    rysc97 Formula Junior
    318
    Netherlands
    Lusso123, Martin308GTB and bigodino like this.
