FCS warning light on 550 | FerrariChat
Discussion in '456/550/575' started by hughmonteith, Oct 14, 2013.
  1. hughmonteith
    hughmonteith Rookie
    Jul 13, 2012
    2
    The FCS warning light comes on when starting my 2001 550,but goes off shortly after. What should I do.
  2. tazandjan
    39,162
    Hugh- Bunch of 550 experts here, not me, but will occasionally happen if parked on non-level spot. Also check and see if the front actuator wires have twisted, a common 550 fault. Download a 550 workshop manual at ferraridatabase.com for more details and a list of what can cause suspenion warning lamps.
  3. pkl03
    pkl03 Formula Junior
    538
    Sydney, Australia
    Peter
    Hugh,
    I have never seen or heard of a FCS light so I did a search and found the following post.
    http://www.ferrarichat.com/forum/456-550-575/84361-550-cold-weather-fcs-light.html
    It appears to be related to the fuel cooling system. I looked at the parts manual and it shows a Fuel/Freon Heat Exchanger fitted to USA and Canadian models. If you use the search function and search FCS you will find some additional information.
  4. hughmonteith
    hughmonteith Rookie
    Jul 13, 2012
    2
    Many thanks.
  5. tazandjan
    39,162
    Whoops, got that one wrong. Was thinking suspension lamp. The Fuel Cooling System is used on the 550 because the injection system has a return from the engine to the main fuel tank and the fuel is too hot to dump straight into the tank. Eliminated on the 575M, which has a returnless system.
  6. Healeyguy
    Healeyguy Rookie
    May 13, 2011
    23
    Funny, I also have a 2001 550 and noticed this the other day.... I wonder if it's got to do with the change in the ambient weather. Always goes off after 10 or 15 seconds.
  7. mcypert
    mcypert Formula Junior
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
  8. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Funny, I got an FCS light for the first time ever briefly just today. I was moving cars around this morning, A/C off. Car drove flawlessly 425 miles yesterday, 120 of them on the track.
  9. billwest
    billwest Karting
    Feb 28, 2008
    60
    AL
    Bill
  10. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    Check your a/c system pressures. You may be low on 134a. That's the first place I would look before doing anything else. Merceds has used this system for years, heck as far back as the 80's in the slclass and s class benzs.
  11. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Terry,
    On my 98 Maranello there is no fuel cooling system. According to Ricambi this began in MY 1999?
    Pete
  12. tazandjan
    39,162
    Pete- Affirmative, only on US and Canadian MY99 and later and looks like the system was heavily revised in 2000 from the first version. Likely had to do with excessive gasoline fumes caused by the hot fuel dumping into the fuel tank, especially when low on fuel. Remember, California has those weird rubber bellows on the fillers at gas stations to prevent gasoline fumes from escaping while refueling and these were all 50 state cars. My best guess.
