FCS | FerrariChat
FCS
Discussion in '456/550/575' started by cgt000, Jul 26, 2020.
  1. cgt000
    cgt000 Formula Junior
    777
    Northeast
    I was driving my 550 last night and the FCS light would come on and go out. Is this something to be concerned about?
  2. Qavion
    Qavion F1 World Champ
    13,951
    Ian Riddell
  3. cgt000
    777
    Northeast
    ^^ Thank you
  4. fatbillybob
    Aug 10, 2002
    28,662
    socal
    Most likely Freon but not always
  5. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    I know this has been discussed a lot.. my light started coming on now that the weather is warmer. When I had the car delivered the fuel cap was missing... now starting to wonder if the PO removed the cap to allow the tank to vent. Light comes on after driving in hot weather for extended periods and stays on.... then I park let the car cool down it doesn't come on again until everything heats back up.... which leads me to believe its legit not functioning as designed. If the Freon pressure is low it would most likely always be on no? Is there a sensor that measures return fuel temperature? I guess no harm in getting a boost in the Freon and see if it helps..
  6. tazandjan
    39,067
    Might keep you from trashing your compressor, too, even if you do not need the AC.
  7. hwyman
    Jun 25, 2015
    329
    AC blows super cold but I could have a pinhole leak
  8. tazandjan
    39,067
    A pinhole leak will drain an AC system pretty quickly.
  9. hwyman
    Jun 25, 2015
    329
    That's what Im thinking since its high pressure refrigerant, I'll get the shop to do a leak down test... do the FCS cannisters commonly fail in these cars?
  10. cgt000
    777
    Northeast
    On mine, the light would come on and then go out every few minutes.
  11. hwyman
    Jun 25, 2015
    329
    Had my refrigerant replaced, full 800 grams came out... so no leak. Had the refrigerant replaced, and on the drive home (warm day) the FCS came back on.... guess it could be a sensor or the FCS ecu
  12. hwyman
    Jun 25, 2015
    329
    Does anyone know the location of the solenoid?
