Feber 430 6-Volt Storage | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by futureowner, Nov 4, 2013.
  1. futureowner
    futureowner Formula 3
    Mar 24, 2006
    1,469
    Brookfield, WI
    Thad
    Let me start by saying I really do not know if this is the "right" location for this thread or not however, I have purchased a 6-volt F430 for my daughter. Car is awesome, runs well and I am sure she will love it.
    That being said, as the winter days of Wisconsin are soon upon us, when I am storing this for the winter do I need to do anything to ensure that the battery stays in good condition? Currently it still has some charge in it (charged it up to make sure it worked) so since it will now sit for a good while, do I need to disconnect the battery, drain the battery, etc?
    This is my first experience with a kids electric car, any advice is appreciated!
  2. no8080
    no8080 Karting
    May 5, 2011
    83
    Uk
    The battery is a sealed lead acid type, it is best to fully charge the battery and disconnect it from the car. Avoid the battery freezing, a stable temperature of around 15 degrees C, 59 degrees F for storage is best.
    So my advice would be fully charge the battery, remove it from the car and store in a cupboard in your house, best to top up the charge every 8-10 weeks. Trickle charging is the ideal option if you have a 6 volt trickler charger, but I wouldn't go out and buy one. Simple storage of the battery is fine.
    Neil
  3. futureowner
    Mar 24, 2006
    1,469
    Brookfield, WI
    Thad
    Thank you! Much appreciated, the car (and battery) will be inside so no worries on the temperature. Definitely do not have much battery knowledge so am thankful for the information.
  4. no8080
    no8080 Karting
    May 5, 2011
    83
    Uk
    No problem, the most important thing about lead acid batteries is they should always be above 95% charge, they hate being at any state of discharged and you will shorten it's life if you do. This is the completely different than Lithium or Nickel batteries we are so used too.
    Best to charge the battery after every use too, this will maximise it's life. Once you take charge out of a lead acid you should put it back in ASAP.
    Neil
  5. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Where did you buy this ?
  6. no8080
    no8080 Karting
    May 5, 2011
    83
    Uk
    Toys r us sell it in the UK and USA,
    Toysrus
    The F430, is a 6 volt one, they also sell a 12 volt 2 seater California. I have this one.
    Neil
