fellow spider owners help | FerrariChat
Discussion in '348/355' started by 355tsr, Mar 19, 2010.
  1. 355tsr
    355tsr Formula Junior
    Mar 9, 2010
    322
    I still am having trouble with my top I nerver paid attention to the cyl squence now I need to know when does the small top cylinders come in to play I think it is only when the top goes up, and they play no part as the top is going down, but I really need to know...if you have a working top on you 355 would you please be so kind as to check it and watch the cyl sequence and report back...thanks
  2. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #2 sambomydog, Mar 19, 2010
    I know the answer to this, but have just been out to the garage to check for you.
    When you unlatch the top leaver and pull the roof back into the ready position. After the seats have gone forward, the upper/top cylinders pull the roof back the rest of the way so its in a vertical position above and in line with the rear of the seats .
    Then the bottom cylinders pull the roof in a downwards motion so its now behind the seats. Then the seats go back.
    I have found these videos on you tube were you can clearly see the roof being pulled back after opening, especialy in the first one. Hope this helps :) http://www.youtube.com/watch?v=JOC7r4EXWsg http://www.youtube.com/watch?v=PpCfX0Y-ILU
  3. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    excellent find !!
  4. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    tick of approval
  5. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Yes 355tsr, you to are very welcome, dont mention it.
  6. 355tsr
    Mar 9, 2010
    322
    Sam thanks, I havent been able to check this until today, your info was right on, my problem is the top CPU is not giving the switching valve a ground (-) so It will not switch in the upper cyls don't know why yet, but I will get there. Thanks again!
