Ferrai Testarossa-front wheel bearing | FerrariChat
Discussion in 'Boxers/TR/M' started by GTTT, Feb 26, 2017.
  1. GTTT
    GTTT Karting
    Sep 7, 2013
    67
    Hi
    Does any one have a cross reference number for the front wheel bearings on 89 Testarossa. I searched the forums and could not find one for the front bearings.
    I appreciate any help in advance.
  2. Steve Magnusson
    26,619
    Not sure an exact cross reference was ever found. My very foggy recollection is that a similar bearing was found that was used on a Citroen (or some other European marque that isn't sold in the US), but something about the built-in seal wasn't quite the same. Have you tried searching on the F PN "112799" and reading those threads and the threads that they reference?
  3. Rifledriver
    36,858
    #3 Rifledriver, Feb 27, 2017
    It was a purpose built bearing for Citroen. Ferrari adapted it to TR, F40, Mondial, 412 and 328. It is not a general purpose bearing and unlikely to be found inexpensively. They were not available for any price for a few years so feel lucky they can be bought at all. They are such a big bearing they can easily outlive the car but no one services them so they die from insufficient lubricant.
  4. GTTT
    GTTT Karting
    Sep 7, 2013
    67
    Hi Steve,
    I will try re-searching the part number by itself again.
  5. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    SKF 441696M is the correct bearing and the dimensions are ID 50 / OD 116 / W 33.8
    Citroen part number is 95548976 and can be used for crossover to other available bearings
  6. GTTT
    GTTT Karting
    Sep 7, 2013
    67
    Hi Arvid,
    Thank you very much, I will try to find the bearing with the numbers you have provided.
  7. Arvid
    May 28, 2012
    668
    Norway
    Arvid Andersson
    #7 Arvid, Feb 27, 2017
    When looking at pictures of Citroen 95548976 the outer ring has 5 holes - Ferrari 112799 has 6. You might want to wait with the "buy now" button as this crossover may be just another pitfall.
    SKF 441696M on the other hand is pictured with 6 holes and corresponds with Ferrari 112799 - so this should be correct.
  8. GTTT
    GTTT Karting
    Sep 7, 2013
    67
    Thank you Arvid,
    I'll continue on the search.
    Best Regards,
    GTTT
