Ferrari 0855 Ellena | Page 14 | FerrariChat
Ferrari 0855 Ellena
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Sep 23, 2014.
  1. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Ed, just stunning. Total respect for you man.
  2. audi_328
    audi_328 F1 Rookie
    2,791
    NH
    Audi
    Just saw this thread and spent the past hour and a half reading every post. Hats off to you, and love the color :)
  3. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    Oh man... This is the fun part!
    It looks stunning
  4. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    With the rear and front suspension in, we got the brakes installed and ran the fuel and brake lines thru-out the car. This was
    thought to make up new lines. I have the brake line fittings already installed to facilitate getting the flairs done correctly, however, come to find out the fittings did not fit thru the rear axle housing, so we had to cut the ends and slip them thru first. It is my belief that the brake lines were put on the car as straight pieces, bent as they felt necessary to hit the mounting tabs and they flared accordingly. Additionally, the brake backing plates and shoes/springs, cams and emergency levers were all assembled off the car originally. I tried to do them the car and with the close tolerances on the back sides to the axles etc, it was impossible to do it this way. Thus assemble all the backing plates on the bench, attach all the parts and then mount the whole assembly. The challenge was now getting to the backing plate bolts in a very tight situation.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    crinoid likes this.
  5. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Oengus, 4re308, stevenwk and 6 others like this.
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Beautiful. Absolutely beautiful:)
  7. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    meadracing, turbo-joe and crinoid like this.
  8. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    crinoid likes this.
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Anodized aluminum would likely be better. To paint the steel, epoxy primer is best for adhesion. But, molded plastic is a bit glossy so I would try to locate a paint that matches. Forgot 3D printing for a component like that. Would require a lot of post processing. Machining was the way to go.
    turbo-joe likes this.
  10. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Another item related to the brakes....so originally when i preassembled the car to see what was missing, one of the emergency brake arm - return springs , that mount on the backing plate was broken. My thinking, wow, where in the heck to i find one of these....well to my surprise one of the big suppliers had them on the shelf! so i order 2, because they are left and right orientation.
    So 2 yrs later i go to install them and i find that they are clocked differently than my original ones. This issue would not allow the arm to mounted with tension on it. Upon questioning what we had here, i contacted the supplier and they never heard of this issue....see pic and you can see the mounting tab is 180 degree out of sync with the original one i have. The solution would be to redrill the hole in the backing plate (which could work fine and is what i think their assembly shop does) or try to find the correct ones.
    Another large supplier did a search for me, and has found the correct ones somewhere....wish i knew where, as I'm pretty good at sniffing out these parts and who makes what. Anyhow i have a correct set coming.....
    My error for not taking closer inspection when the parts arrived 2 yrs earlier.....just a subtle difference, but one that held up the assembly for a week sorting this out.
  11. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Thank you for the advise - i made several sets so i may experiment a little with the anodized approach.
    Oh, i stand corrected -we did make them out of alum...just forgot what we did!!
    So the anodized process can easily be done.
  12. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Everything looks great. Keep it up, Ed.
    john
  13. kare
    kare F1 Rookie
    Nov 11, 2003
    3,847
    Any serious spring manufacturer will make you new ones in no time for peanuts, let's say $100 for a pair - or a few hundreds for 100 pairs.
    Dave rocks likes this.
  14. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Thanks John,
    kare, i got a pair coming from GTO....never had springs made before - that is intriguing ...
  15. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    mockingbird812 and Dave rocks like this.
  16. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Started to add a little of jewelry on the car today......
  17. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Currently working on the timing cover for my engine guy. The timing cover has a lot of responsibility, water pump, generator, fuel pump, oil pump, tensioner, cam gears etc.....
    A lot of mechanical analysis, new parts and tolerance evaluations went into fitting all the parts and the timing gears.
    The engine guy want to install the timing cover, and cycle the engine over to assess the valve to piston clearances
    before the final assembly. I said i would do the timing cover pieces - which took way way more time that i expected - however they needed to be done and correct, and i learned a lot! Once all the items have been fit and tolerance assessed and fixed, then off to paint, plating of the bolts/nuts and assembly. So...i think I'm there - delivery tomorrow to the engine builder for his piece to complete and hopefully final assembly.
    A heck of a lot of detail when you take the time to look at everything!
  18. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    #343 John Vardanian, Jan 30, 2019
    Looks great Ed.
    Is the big domed nut part of the tensioner?
    Seeing the 1, 2, 3 stamped on the intake manifolds made me remember something. The 12 holes in my air filter box used to line up with the carb studs just fine. Then once I had taken things apart and after I put them together the studs no longer lined up. It was a big pain in the butt figuring out the right order so things could line up. Do you know if your 1 is in the front or in the back? If not, figure it out before you torque everything down. For that matter, I can't remember if each casting can be flipped either way, if so, that would add even more confusion.
    john
  19. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    I think no. 1 is front of engine
  20. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Yes big dome nut cover the tensioner adj screw ......
    Numb 1 is front of engine - believe was done by previous owners.....not me
  21. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,582
    Grant
    Great job Ed :)
  22. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    590
    SW Suburbs of Chicago, IL
    Lawrence P.
    It is really starting to come together. The detail is spectacular.
  23. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Started to add a few more bling items to the car....i could not hold back, wanting to get a look at the
    Marshall Headlamps, buckets and Chrome Rings i made.
    I also installed the chrome grill surround - the paint job it took up a few more MM of space
    that i could not afford to lose on the grill fit. It took a while to get this in without scratching and
    a little force to get the screws started. I have to say, the fit looks real good - these grills unlike the later cars do NOT get the rubber grill surround piece. This would hide a bit of anomalies and fit with the grill. These grills have to fit right on with the front nose edge - uniform all the way around. I know we worked this grill many many times, in and out to make this happen.
    Im in the process of have new grill slats being water jetted - once they get back, ill have to do the end to end
    measurements, trim, fit, fit and fit, trim, trim and refit :). This will be a tedious process getting the egg crates perfect look vertical and horizontal. More of this later when the parts arrive.
    Boudewijn likes this.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Such a beautiful car and killer workmanship :)
  25. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Last weekend i also started on some interior pieces - getting the new door panel material, rear luggage shelf, side panels and the kick panels remade and fit to the car. I wanted to get on these and do the work myself, so i can get the upholstery guy to begin to assess what needs to happen. Im thinking i might have used a slightly too thick panels....orig's are 1/8 and I'm using the 3/16.
    Im hoping this is not an issue.....
    Just realized i did not snap pics of the new stuff.....will do
